Roof Nets
Except when your tall. I drove an SPB with one at a high speed track in a DE and I was amazed at how much it flapped around. It was slapping the top of my helmet and also partially blocking the rear view mirror once the car was really moving. Glad I got to try it out as I had thought about getting a roof net.
I must be the odd man out. I like arm restraints. The drivers who drive the fastest cars in the world use arm restraints - top fuel drag racers. That's good enough for me.
I'm in....
I installed mine under the cage but I pulled the padding on the cross tube, sandwiched the net between the cage and the pad and then zip tied it tight. I haven't tried it yet but it doesn't seem like it's going to move much.
I'm in....
^ I may worry too much but it's possible for a hand to get above the cage and be crushed if you roll more then once when the net is on the outside like that. I know that the probability is low but putting it on the inside all but eliminates the chance.
Our cages have grab handles/braces by the top of the windshield and the mini FIA bar we use also serves as a handle to assist exiting the car.
Aside from that, the netting should flex enough to grab the bar.
