Spec Boxsters For info sharing on this exciting new class
eliminating ignition key for push button
Old 08-12-2022 | 04:50 PM
Drejw2's Avatar
Drejw2
Default eliminating ignition key for push button
Looking to eliminate the key to turn the car on, we have only one key and it's falling apart. I understand that there is a rig that needs to be kept or it can cause problems, has anybody done it for there boxster? any idea where I should look? or ask?
Old 08-13-2022 | 12:10 PM
tgsmith4845's Avatar
tgsmith4845
I had the same issue with my SPB, only 1 key. Rather than replacing the key with a push button system, I just removed the key pill and taped it to the transponder by the ignition. Then had a spare key cut for $30. Done. And I don’t have all the issues with adding a master power switch and start button.
Drejw2 (08-15-2022)
Old 08-15-2022 | 01:22 PM
Drejw2's Avatar
Drejw2
where would the transponder be? by the ignition switch. thank you for your tip.
Old 08-15-2022 | 07:32 PM
jerome951's Avatar
jerome951
I did the same as Tim, however I had to fiddle a bit with locating the pill on the ignition switch for them to 'talk'. I ended up pulling the trim bezel off the front and taped the pill near the closest edge.
Drejw2 (08-16-2022)
Old 08-16-2022 | 11:50 AM
tgsmith4845
yes, by the ignition
Drejw2 (08-16-2022)
Old 09-19-2022 | 01:00 PM
Matt Marks's Avatar
Matt Marks
Here is how I did it:
https://rennlist.com/forums/spec-box...ton-start.html
Old 09-19-2022 | 02:04 PM
PGas32's Avatar
PGas32
What’s the legality of this? There’s nothing in the rule book that says modifying the ignition is OK. Obviously no performance advantage, but I can think of folks who would protest someone over this
Old 09-19-2022 | 05:44 PM
Streak's Avatar
Streak
Perfect Angel
I'm way ahead of you. Papers filled out and ready to go!
Old 09-19-2022 | 06:19 PM
RennPart's Avatar
RennPart
Basic Sponsor
key's from Barb's corvette gave me the win back at dega. GOBLESS
rennpart.com | Phone: 336-793-2134 |Email: ace@rennpart.com
Instagram | Facebook
Streak (09-20-2022)
Old 09-19-2022 | 07:38 PM
BillC3's Avatar
BillC3
I don't think it would be a problem. I've seen plenty of SPBs with this mod, and the scrutineers never said anything.
Of course, the best person to ask is Walt Fricke (walterfricke@msn.com), if you are considering this modification.
Quick Reply: eliminating ignition key for push button
