996 Forum 1999-2005
***Install aftermarket head unit in MOST car WITHOUT removing factory amp***
Old 09-15-2016, 08:46 PM
Turbojamie
Turbojamie's Avatar
Default ***Install aftermarket head unit in MOST car WITHOUT removing factory amp***
Gentlemen years have gone by with NO solution to installing an aftermarket head unit into an 03+ Porsche without the need to remove the factory amp and add all kinds of aftermarket wiring, etc to make it work. Well NO MORE!!! I took a stab at trying this RCA to MOST fiber optic converter and it WORKS. Now you can install an aftermarket head unit into an 03+ 996 and retain the stock amp.
This is HUGE IMO and no one has done it that I know of so far.
I will edit this post as I am going to now remove the ipad and install a double din head unit for testing, as well as provide the link to purchase the box. It was $127.00 Canadian shipped to me and I had it in 3 days from Hong Kong. I did pay an additional $20 customs.
kevin mickle (08-25-2019)
Old 09-15-2016, 09:38 PM
JohnCA58
JohnCA58's Avatar
Great news
Old 09-15-2016, 10:32 PM
schundg
6th Gear
schundg's Avatar
Ahhhhhhh, just installed a pioneer double din along with a new amp ... never thought there would be a working solution to MOST.
Old 09-15-2016, 10:43 PM
Turbojamie
Turbojamie's Avatar
Neither did I, personally I could not be more excited.
Old 09-15-2016, 11:17 PM
Rpompea
Rpompea's Avatar
Ditto,
Please share this magical unicorn of a device
Old 09-15-2016, 11:53 PM
Turbojamie
Turbojamie's Avatar
I'll post the link tomorrow from my laptop to the device it's so simple now to swap a deck!
Here is the other thread with the link to the box I have.
https://rennlist.com/forums/996-forum/949822-03-carrera-4-s-radio-upgrade-2.html
Old 09-16-2016, 07:04 AM
philooo
philooo's Avatar
this is hugeeee.... I have been waiting for this for...5 years ! my stock head unit days are counted
Old 09-16-2016, 10:12 AM
ZuffenZeus
ZuffenZeus's Avatar
Received 1,673 Likes on 923 Posts
Great work Jamie! Your willingness to go through the trouble of testing this devise has saved a lot work for all of us in the 996 community. Personally, I think the systems go bad because of the Becker HUs, but the speakers and amps are still good. Therefore, this little unit will make it possible to replace the radio and still keep the existing components. Awesome!
There is ONLY one problem... will someone want to purchase the box at $127 - $150 when there is a slight chance the Becker MOST based amp could be bad? I know you said something about a return, but sometimes, it's too costly to return something internationally.
Anyway, keep up the good work and let us know what head unit you use in the car.
Old 09-16-2016, 10:25 AM
ZuffenZeus
ZuffenZeus's Avatar
Jamie, am I wrong here, but since the unit is essentially an analog to digital conversion box, you'll lose some control such as fading (front to rear). I assume you can still balance left and right since we're talking about stereo RCA output into this box, but fade control will not be possible, right?
Old 09-16-2016, 11:31 AM
Turbojamie
Turbojamie's Avatar
im going to say your right we likely have left and right balance but not likely fade. I won't know until I put a head unit in. At this point all I know is all 6 speakers work and sound better than they did stock with the big eq app I have on the iPad.
Old 09-16-2016, 01:32 PM
JohnCA58
JohnCA58's Avatar
I ordered a unit, I am going to try the unit with a Alpine 149 BT, going to go over to CAI and pick up his plug and play wiring kit and ask if he will just add my unit to piggy back onto his harness, no doubt there will not be any fading since there is only one set of RCA cables, it will be interesting to see how it works with the Alpine HU.
Old 09-16-2016, 02:02 PM
llis
llis's Avatar
This is wonderful. Thank you for experimenting and sharing the knowledge!
Old 09-16-2016, 02:31 PM
thebowl
thebowl's Avatar
A really nice five channel power amp can be had for $350. Just sayin'
Old 09-16-2016, 02:36 PM
Turbojamie
Turbojamie's Avatar
plus power and ground wires, plus trigger wire, plus 3x rca cables. Plus having to modify the car...
Old 09-16-2016, 03:29 PM
thebowl
thebowl's Avatar
Alpine makes a unit that fits with no mods required.
Quick Reply: ***Install aftermarket head unit in MOST car WITHOUT removing factory amp***
