996 Forum 1999-2005
Our 996 refuses to run over 4500RPM!!!
Old Apr 21, 2025 | 01:50 PM
750machiv's Avatar
750machiv
Default Our 996 refuses to run over 4500RPM!!!
Strange thing: our 996 refuses to accelerate over 4500-5000RPM!
It is running well under this limit; good acceleration... But it begins toi jerk horribly when it reaches 4500RPM and refuses to pass over!
It's equiped with a tiptronic gearbox. Changing gear is not a problem and works perfectly, in manual or automatic mode.
Any idea??
Thanks!
Old Apr 21, 2025 | 01:52 PM
BmoreHokie2's Avatar
BmoreHokie2
Most likely the crankshaft position sensor. Thats a common symptom of what you're experiencing
Old Apr 21, 2025 | 02:08 PM
750machiv's Avatar
750machiv
Yep, this could be the cause...
Will try to change it!
Thanks a lot for your reply!
Old Apr 21, 2025 | 03:31 PM
De Jeeper's Avatar
De Jeeper
Probably not the issue but check to make sure there is good flow out of the exhaust. U should be able to detact it with just a glove on over the exhaust pipe to see if u had a cat come apart and restrict flow.
Old Apr 21, 2025 | 04:00 PM
theprf's Avatar
theprf
Split fuel line in the fuel tank. It will keep getting worse.
Take out the fuel pump and inspect all the hoses. The "U" shaped rubber hose is probably split. Replace it with submersible fuel hose (not ordinary fuel hose!).
Old Apr 21, 2025 | 04:24 PM
750machiv's Avatar
750machiv
I can't imagine an issue with fuel line.
Why? because I did tests at full charge under 4500RPM and accelerations are proper up to 4500RPM.
If I'm trying to pass over 4500RPM slowly; that remains the same: engine is immediately jerking horribly, Rev counter is sweeping from 2000 to 4500!!!
I'm mostly looking in direction of an electrical/electronical issue! Maybe a DME failure, or something similar.
Understand me, if you stay under 4500, the car is going very well, even if you accelrate strongly or lightly.
I'll also explore another way, by servicing the tiptronic...
Will let you know...
Cheers,
Old Apr 21, 2025 | 05:25 PM
De Jeeper's Avatar
De Jeeper
Dont discount the fuel line. Its an easy check.....
Its a matter of volume and pressure. A split in tank line will cause the issues u r having.
Will the engjne rev over 4500 when in park or neutral (no load)?
Old Apr 21, 2025 | 10:37 PM
Porschetech3's Avatar
Porschetech3
Keep in mind along with these other possibilities that the DME may have somehow got back into "transport mode" ..
In Transport mode the RPM's are limited along with other non-essential functions that are not necessary when transporting across the Ocean for months..
Performing a "Handover" with a PIWIS Tester will take the system out of Transport Mode.....I have seen a few cars that had gotten back into Transport Mode somehow due to some strange voltage/electrical issues..
It's worth a mention !!!
Old Apr 22, 2025 | 04:47 AM
750machiv's Avatar
750machiv
Thanks for this!
I have a PIWIS 2 and an original 3.
Have you a procedure to do such operation?
FYI: I've already changed the crankshaft position sensor, without any effect...
Old Apr 22, 2025 | 05:18 AM
Porschetech3
Originally Posted by 750machiv
Thanks for this!
Just get to the 996 main menu , then look across the bottom for "additional menu", then select " Handover" and follow the prompts .......
If this doesn't fix it then put a fuel pressure gauge on the fuel rail and test the pressure at full throttle up to where it cuts off...Fuel delivery is the number 1 cause of full power issues...
Old Apr 22, 2025 | 11:34 AM
750machiv's Avatar
750machiv
Thanks for the process. I did it and wait for the result from the owner...
In the meantime, I servised the tiptronic and noticed problem with tiptro switch connector!!
Piwis indicated wrong tiptro position !!!
I sprayed some contact cleaner and all come back to normal on this point. Better than nothing!!
Old Apr 22, 2025 | 11:35 AM
750machiv's Avatar
750machiv
To complete the topic, spark plugs and coils were already changed!
Old Apr 22, 2025 | 11:45 AM
Viper1000's Avatar
Viper1000
Just a crazy thought but I would assume you looked at the air filter? Any issues with restriction?
Old Apr 22, 2025 | 01:14 PM
750machiv's Avatar
750machiv
With air restriction I couldn't accelerate "foot in" at low rev!
Here the car is running perfectly with "heavy acceleration" up to 4500RPM!
Then, I'm doubful about any air restriction due to dirt air filter.
But, thanks for your suggestion.
Old Apr 22, 2025 | 02:13 PM
Viper1000's Avatar
Viper1000
Boy then it has to be on the fueling side. Does it struggle after 4500 or just dies off? If it's struggling, it's fuel pump or fuel filter related. It wouldn't be dirty injectors if it's pulling hard to 4500....so my thought is it would have to be the fuel pump or filter? Hummmmmmmmmm
