Serpentine belt recommendation 01 C4
Since I don't know the last time my serpentine belt was replaced (bought the car used) I'm thinking of doing it in the coming weeks. It does whine a little (if not started for a few weeks and only for a minute or so) until it warms up then goes away. The car does have AC. I noticed several available and the pricing is all over the place.....any recommendations on type I should get?
Viper1000 (09-19-2024)
I recently had 2 idler pulleys and the belt replaced on my 99 996.1 3.4. Here were the part numbers used:
997-102-118-00 idle roller
997-102-119-00 idle roller
996-102-151-68-OEM 6РК2115 BELT
Thank you Sir. I'm assuming yours has AC correct? Apparently the belts are different sizes if you don't? Thanks again!
The following 2 users liked this post by Porschetech3:
Mike Murphy (09-20-2024),
Viper1000 (09-20-2024)
Kit with belt and pulleys. I also found the plastic pulleys wore out and developed unusual surface over time. I'm replacing them with the metal pulleys like this kit: https://www.pelicanparts.com/More_In...c&q=serpentine
If you can believe it, my local Porsche dealer has the belt in stock for $75/out the door! I'm amazed they didn't increase the Porsche tax...LOL. I'll take a peek at the rollers once in there and see if they need replacing as well. Should be a simple job.
Woooo thats nuts! Think I might have to order that one!
Continental $15
https://www.fcpeuro.com/products/por...er-67643004259
