Aluminum in oil 2010 Turbo S
Old 07-15-2024, 09:04 PM
Badchoice
Cruisin'
Badchoice's Avatar
Default Aluminum in oil 2010 Turbo S
So it looks like I messed up..
I bought a new to me 2010 CTTS with cranking issues and 150,000 miles. It takes quite a few cranks to start up, with camshaft codes, once it does, it drives great. Power seems to be all there. In the 2000 miles I put on it, it didn't use any oil. Borescope didn't reveal any bore scoring. But... I just got my oil analysis results and I'd say it's catastrophic. I found some metal shavings when changing the oil as well. Aluminum levels are triple the universal average. Iron is nearly double. Everything else is within normal. What am I most likely looking at? Bearings? Pistons? Timing chain?
Old 07-15-2024, 09:29 PM
TRINITONY
TRINITONY's Avatar
Did you see the borescope pics? How does the engine sound?
Why not post up the report.
What oil are you using? Might be time to add some Ceratec.
Old 07-15-2024, 09:48 PM
Badchoice
Cruisin'
Badchoice's Avatar
I did the borescoping, looked perfect...
Engine sounds great, nice and quiet, pulls strong.
I don't know which oil was in it, I replaced with Liqui Moly, and I did add Mos2, which is same as ceratec just less concentrated as far as I know.
Old 07-15-2024, 09:56 PM
BobcatBrian
BobcatBrian's Avatar
Do a leak down test and report back with results. Also, what cam codes?
Old 07-16-2024, 04:03 AM
Badchoice
Cruisin'
Badchoice's Avatar
P0344
could I be seeing this much metal from a timing chain rather than bearings/pistons/cylinders?
Old 07-16-2024, 05:14 AM
hahnmgh63
hahnmgh63's Avatar
With that mileage I would put it on a scope and measure the Timing syncronization. Could be a guide that has failed and the chain is wearing Iron (Steel) for sure and maybe rubbing the inside of a cover for Aluminum. Stop driving it as the metal in the oil isn't going to do you any favors, the filter doesn't get all of it.
BobcatBrian (07-16-2024)
Old 07-16-2024, 07:24 AM
Petza914
Petza914's Avatar
Received 6,659 Likes on 4,232 Posts
The paddle under the chain guide is probably aluminum too so once the pad is worn through that could be the source of the aluminum. Any bits of plastic in the oil filter media?
Post the UOA report and photos of the oil filter media layef out flat
Old 07-16-2024, 09:38 AM
BobcatBrian
I was thinking chain guides as well, but wouldn’t that make a lot of noise at idle? If you have to pull the engine, do the mounts while you have access.
Old 07-16-2024, 09:41 AM
Petza914
Petza914's Avatar
Yeah, you'd definitely hear it if that was the cause of the aluminum. My guess is cylinder scoring that's still below the piston and not visible through the plug holes yet.
Was this a cold climate car at any time during its life?
Badchoice (07-25-2024)
Old 07-16-2024, 12:00 PM
BobcatBrian
Bore scoring would be a very interesting data point with this being a 2010 model CTTS.
19psi (07-16-2024)
Old 07-16-2024, 03:08 PM
FrenchieDadRS
FrenchieDadRS's Avatar
agree
Old 07-16-2024, 03:56 PM
hahnmgh63
hahnmgh63's Avatar
Jake Raby did say that Bore Scoring tended to start at the very bottom out of view of a bore scope then it would eventually work it's way up with use. He advocated pulling the pan and scoping from the bottom but that's obviously a big job. I think the Timing chain with that kind of mileage is still a good possibility and much easier to check and rule out. Either way it shouldn't be driven anymore if you hope to save the engine and it would help to post the Oil analysis as mentioned above by Petza.
Old 07-16-2024, 10:13 PM
theprf
theprf's Avatar
Received 1,860 Likes on 1,183 Posts
Scoping from the bottom is not possible on these V8's. The bottom of the crankcase is two pieces like a 928's V8.
Old 07-17-2024, 11:19 AM
TRINITONY
TRINITONY's Avatar
Good to know, still post the report though. Curios to see the other wear metals.
Old 07-25-2024, 08:06 PM
Badchoice
Cruisin'
Badchoice's Avatar
So, got the valve cover gasket off, and noticed these "scratches" on the cam itself! Could this be the source of my aluminum and iron in the oil analysis?? What could have caused this to happen in the first place?
Quick Reply: Aluminum in oil 2010 Turbo S
