Interior noise level Carrera T
Can someone that experienced the 991 or 992 Carrera T let me know how the interior noise level is ? I heard on some video reviews that because the sound isolation is stripped on the T the engine noise is louder, im ok with that .. but how is exterior noise in the highway for example ? Highways are super loud, trucks are loud, everything , is it an issue for some people ? thanks!
The T may be the wrong car for you if you are concerned about interior noise levels.
Porsche992 (01-24-2023)
My recommendation is to spec any 992 with noise insulated glass. It cuts down road/wind noise as intended, but also improves interior engine acoustics. Even better if you combine noise insulated glass and rear seat delete (GTS).
The following 2 users liked this post by d6veteran:
Porsche992 (01-25-2023),
Tompoodie (01-27-2023)
I would love to see someone actually show data to support the noise insulated glass commentary. I actually have it on my 992S but I have nothing to compare it to since I haven't driven another similarly equipped 992 back to back. Something tells me that I wouldn't be able to tell the difference!
Isn't the GTS noise profile similar to what you might expect in the T? Maybe someone can answer up in that regard. but I haven't heard any complaints from them so maybe nothing to worry about.
I drive a CAB with Akropovic Sport Exhaust and I would expect the interior noise to be louder - in general - than a coupe. So far, I don't have any issues with 80MPH roadtrips that are 6 or 7 hours long with the top up or down. No noise fatigue or anything like that. I fall out of the car like a crumpled piece of foil at the end of the trip but, other than that, no worse for wear.
The following 2 users liked this post by breny4104:
OMTarga4S (05-01-2024),
All 911's are relatively loud. My GTS's primary loudness is road noise and it doesn't matter which 911 you choose, you're going to get that. GTS and T have somewhat reduced sound isolation, but are not significantly noisier than Carrera, S, etc. You can opt for even less sound suppression, and I can't address that from experience. The current crop of 911's share similar sound characteristics (less the GT3's): some exhaust, some induction, more road. If you've test driven a 911, regardless of model, you've experienced "the sound." The differences from Carrera to Turbo S aren't significant. Now if you want a wailin' flat six sound, the GT3 will not disappoint.
The following 3 users liked this post by F8Driver:
Received 2,704 Likes
