2003 996 4.0L Upgrade w/ Spec Racing Suspension
Year: 2020
Make: Porsche
Model: 911
Mileage (numbers only please): 84000
Options (Please check ALL which apply): Airbags, Air Conditioning, Antilock Brakes, Cruise Control, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof
Color: Silver
VIN: WP0AA29963S622416
Price (no $ sign please): $39900
Location (Region): SouthEast
Body Style: Coupe
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Upgrade list:
LN Engineering 4.0L upgrade at 81,000 miles
101mm Nickies
101mm 11.8:1 996 JE Piston Set w/ rings, pins, clips
R&R Pro Billet Porsche I-Beam Connecting Rods
Custom Head Gasket Set
Replacement Triple Row IMS Bearing
Chromoly Oil Pump Hex Drive
Billet Crankshaft Tensioner Paddle
Porsche Motorsport Air Oil Separator
Porsche OEM Water Pump
2004 Porsche OEM Heads
Joe Gibbs Driven BR40 10w40 oil used during break in
Joe Gibbs Driven HR High Zink 10w40 oil used consistently after break in
Dyno Tune at At Speed Motorsports, Hanover MD
Wheel Torque 317 lbft
Wheel Power 335 hp (approx. conversion 390-400 crankshaft hp)
Engine is bullet proof
Tarett Engineering 996 Spec Racing Suspension Package
JRZ RS Coil Over Kit – 996 Spec Racing Package
Front Swaybar and Drop Link Set, 26.8mm, 5 position adjustable
Rear Swaybar and Drop Link Set, 19.1mm, 4 position adjustable
Front Monoball Camber Plate Set
Rear Monoball Camber Plate Set
Rear Toe Link Set
GT3 Lower Control Arm, Front and Rear
Transmission rebuild at 82,054 miles
OZ Racing wheels Alleggerita HLT Titanium, Front 18x8.5, Rear 18x11, 2 sets
DAS Sport Bolt In Roll Bar
Sparco Evo Racing Seat, 2 each
Sparco 6 Point Harness, 2 each
Wevo Stainless Steel Motor Mounts
Semi Solid Transmission Mount
3rd center radiator
Fister Sport Exhaust
Fabspeed X Pipe Cat Delete
SRF Brake Fluid
Front brake pads – Pagid Yellow
Rear brake pads – Pagid Black
Car has a good title and is driveable on the street
I have the OEM leather seats and they will go with the car
Cell 757-615-6005, mhauser@centuryconcreteinc.com
This looks like an awesome sleeper 996. Do you have a dyno chart?
