Dension Gateway 500 - CDC Enabling with PIWIS
#33
Yea you not be able to get the ipass/learning code from them. Those are protected very well, only the Service manager or lead tech/Gold Meister tech will have access and probably will not give them up, maybe some sort of legal issue but I never gave then up,of course I never had a customer/owner with his own PIWIS II ask for them..lol
#36
Your welcome !!
Thanks again
#37
I know this is an old thread, but does anybody know how to program/code the new PCCM + using a PIWI 2 into the system? What I am trying to accomplish is to have the navigation information from the PCCM + display in the instrument cluster. I realize that the PCCM + is pretty much plug and play out of the box and requires no coding, but in order to get the function I desire some coding needs to happen to get the data to the instrument cluster.
My current configuration is MOST base system with CDR-23, CDC, and Bose.
Thank you!
Thank you!
#38
Thank you!
Thank you!
#39
8 Programming PCM2 with PST2
8.1 Activate PCM2.
8.2 Read out PCM2 fault memory and erase.
8.3 Match the MOST required installed components list to the actual installed components list.
8.4 Code the PCM2 according to vehicle type, versions, country-specific tuner settings and MOST switch.
8.5 Check MOST components.
8.6 Activate navigation in the "instrument cluster" control module system.
8.7 After programming is finished, read out the fault memory of all systems, remedy any existing faults, and erase fault memory
I am not sure how to do it with my PIWIS2. Does the PIWIS have to call a Porsche online account? Is the command structure like the PST2?
#42
PST2 and PIWIS2 are very similar and now PIWIS3 is similar to PIWIS2.
So you should be able to use the instructions you've posted. If you're unsure use the simulation mode to find what you're looking for.
#43
Thanks Dan, that sounds like a good plan. Will I need a Porsche online account to do this?
#44
