I'm sick...think my car is developing "The Stumble"
#271
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/750x1334/img_0414_png_3fad0d914ad72a0c5285a00439348ed191f3c867.jpeg)
Not saying this is what they did but I had this saved on my iPad.
#272
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/750x1334/img_0414_png_d9986727ca43c15bc1f5426032d7e487eb847817.jpeg)
Not saying this is what they did but I had this save in my iPad.
#273
It's really time that Porsche owners get at least basic access to the computers in there. The BMW folks are way ahead.
I'm not talking about replacing the transmission software or control turbo boost from your iPhone.
It is certainly not OK to have some kind of auto-learning system in there that can be reset at the dealer for $$$ and is closed to the user. And in any case, it would be constructive to not just reset those learned values that turned bad, it would be much more useful to collect the bad values, compare to values from cars that stayed good over the same usage period, and then have a deep look. You know, Porsche might actually *fix* the software. There is a radical thought.
#274
So if you try the ignition on/off fix as described above, what do you do after the (second one) 15 second interval? Start immediately, or back to off and then normal start whenever you want?
#275
Update on my O2 sensor replacement: unfortunately it did not fix the stumble problem. It seemed improved for a day or so, but then back to the usual hesitation/stumble.
#276
Next step for me is to do a smoke test to rule out vacuum leaks. Then I'll investigate the throttle body a little more.
#278
His reply to me was:
"Yes the throttle adaptation can be done simply by turning on the car for a few seconds without starting it that's a common procedure.
The torque lost adaptation is more of an missions thing but if it's working that's great."
#279
"Either/or. Once you hear it go through the click process, it's done."
Click process is the noise you can hear at the throttle body. He says its not too loud, and can hear better with rear lid open. Which I don't have with my Targa. I'd suggest doing this in a quiet setting if you want to hear the throttle body 'clicking' as a confirmation.
#280
I sent the above screen on the ignition On/Off procedure to my trusted Porsche Indy (used to work for Porsche at the dealership here in Baton Rouge). I asked him if he was familiar with the this procedure.
I think it's a little more detailed than the reset procedure.
I have gone through the reset numerous times with no noticeable difference.
I'm aware of another system reset performed by the shop computer.
#281
Since the dealership reset both of them on mine, I can't definitively say that one or the other or both were required to correct the stumble issue that I was encountering. Nor can I confirm that they reset Throttle Adaptation with their computer diagnostic equipment or just using the key On/Off method.
The good news is that it seems that the key On/Off is simple enough to do by any of us. If this was the reason for my problem, I immediately noticed 2 things:
1.) First time driving away from the dealership, when picking up the car, the throttle input took just a little more input from my foot to get the car moving. This was only noticed due to muscle memory in my foot when starting from a stop (manual transmission).
2.) My stumble was gone.
So, my suggestion is to try it. Watch for the 2 above possible scenarios to see if you feel any difference.
#284
20 pages later and I still haven't brought my car in.
