New Radiator Recommendations
Old 08-26-2017, 06:53 PM
John S. Markowitz
John S. Markowitz's Avatar
Default New Radiator Recommendations
Hi All
Going through a bad patch w my car- one damn thing after another.
Any recommendations for an aftermarket radiator. It has the original Behr radiator in it that is now leaking and I am perfectly fine with any replacement that did as well as the original that lasted >25 years.
I do not seek the best radiator on the planet- just a solid stock replacement or similar.
Thanks in advance
John
1991 928S4
Automatic
Old 08-26-2017, 07:01 PM
NickTucker
NickTucker's Avatar
I went thru a few Behr units until I gave up and went with a C&R all aluminum radiator. 928 International was selling it..
Never had a problem since and it's been over 10 years....
GUMBALL (02-17-2024)
Old 08-26-2017, 07:51 PM
Chalkboss
Chalkboss's Avatar
CSF all aluminum radiator from 928 Int. Fine quality. Buy factory looking stickers from Roger and you're good to go.
Old 08-26-2017, 08:35 PM
SeanR
SeanR's Avatar
What they said. The CSF from 928 Intl or through Roger @928sRus.
Old 08-26-2017, 10:22 PM
John S. Markowitz
Default Sounds like a plan to me
Thanks fellas
I'm not 25 miles out from a sheared-off torque tube repair and a new window controller module and now this. I suppose these cars are getting up there in car years!
As always- thanks for the input!
Old 08-27-2017, 12:18 AM
leiplouis79
leiplouis79's Avatar
Here is a Pic of the CSF in my car - got it from Roger -
The following 2 users liked this post by leiplouis79:
GUMBALL (02-17-2024), JBT3 (02-18-2024)
Old 08-27-2017, 10:46 AM
ammonman
ammonman's Avatar
Where is your current Behr unit leaking? The usual issue is the PS plastic end tank right at the inlet nozzle. New tanks w/seals are available from the Big 3 and there is a great write-up on how to replace them here on the forum. I did both mine about 5 years ago and have not had any issues (and I daily drive my 928.) If your core is leaking then a new CFS from Mark/Roger would be the best route IMHO.
Mike
Old 08-27-2017, 11:05 AM
Live2Hover
Live2Hover's Avatar
Hey leiplous79 where did you get those cool looking air intake hoses? They look great!
Old 08-27-2017, 11:11 AM
Petza914
Petza914's Avatar
I've had the 928 Motorsports all aluminum radiator and expansion tank in my 928 Spyder for about 3 years now, no issues at all. Also have their push/pull fan setup and controller
Old 08-27-2017, 11:34 AM
John S. Markowitz
Default Radiator issue
Mike
erday.
Hi Mike
Thanks for pointing that out, and I'm not positive, but that could be where the leak is- my mechanic just pressurized and looked at it yesterday-I will double check with him on this.
Would be nice to find out this was the issue
John
Old 08-27-2017, 11:55 AM
Koenig-Specials 928
Koenig-Specials 928's Avatar
Originally Posted by Petza914
I've had the 928 Motorsports all aluminum radiator and expansion tank in my 928 Spyder for about 3 years now, no issues at all..........
I have the same for more than 5 years now. Also no issues
Old 08-27-2017, 03:42 PM
mdkelly1
mdkelly1's Avatar
+Another satisfied customer here for the CSF unit. Replaced the leaking Behr unit with the CSF radiator and it works great!
You can get the CSF unit from 928 International and 928sRus. In addition to the great cooling, new stickers from Roger made everything look new again.
Old 08-27-2017, 03:52 PM
Chalkboss
Chalkboss's Avatar
Here's what the CSF radiator looks like with reproduction stickers as I described above. I have the old Behr which has a leak in side tank sitting collecting dust- I just wanted a new fresh unit in there.
JBT3 (02-18-2024)
Old 09-12-2017, 12:58 PM
John S. Markowitz
Some beautiful engines there boys and girls!
Old 09-12-2017, 01:33 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,177 Likes on 1,231 Posts
Which radiator did you end up going with?
Quick Reply: New Radiator Recommendations
