How 'special' is the new GT2RS engine really?
It's clearly more special than the Turbo S Exclusive engine. Beyond that I don't know.
This car is destined to be a garage queen. If it ever got put through a rigid test by customers I have a feeling that reliabilty issues may arise especially in hot climates.
The more I ponder it the more reasons I find to pass and wait for .2GT3RS.
If I pulled my money off like sheets of toilet paper it would be a different analysis.
Plus I love the fact the GT3/RS has roots in Motorsport and was motorsport from '15 onward. GT2RS not so much.
The car is running 1) a maximum boost pressure of 1.55 bar and 2) is utilizing a water injection system to keep IATs down so the car can continue to utilize higher boost pressures over a greater range of ambient operating temperatures. To me this represents a break from Porsche's previous philosophy of lower boost pressures, broad power band, and expensive intercooling.
With that in mind, does anyone know how the efficiency of these ICs stack up to the ones in previous 911 Turbos? My suspicion is that with more expensive ICs there may (guessing here) not be a need for the spray system. Said differently, there may be additional efficiency that could be captured if the hardware had been more expensive. Sorry guys, I'm thinking out loud here because I'm trying to piece together what I've read in other threads about boost/IC efficiency.
The other question I had is about lag. If Porsche are willing to have the driver incur a little lag with the pursuit of bigger turbos that work better up top, on the track, and with shorter gearing, how are they deciding how much is appropriate? I suspect that because modern turbocharged cars are so efficient, any compromise for more power with more lag is going to be quite noticeable. At that point, what becomes acceptable? I'm pretty sure that during one of the reviews of the Mclaren 570 against the 911 Turbo S, the journalist indicated that the Mclaren felt laggy, but had ultimately had better acceleration. This may not help in more real world conditions (back roads, getting on to the highway, etc), but on a track, airfield, or autobahn, would the pursuit of better numbers be more important to the buyers and the marketing department?
Race Director
Just buy a Turbo S, throw a tune and a wing on it and magic- you will still have s car that will catapult you to all speeds and more car than one can manage
This whole GT2RS fixation I find hysterical. The car is over priced and Porsche must be laughing in the board room as they are stuffing their sox with money
delete
To the original question, I'm sure we'll find high 90s percent of parts are shared with the other engines in the family, likely far more than the GT3... That's not really a knock keeping the extreme modularity in mind. A base Boxster shares over 90% of its core parts and ancillaries with a Turbo S, including critical ones you'd never guess at such as main engine bearings, block, etc.
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_9267_73bbebb0e8d7196f95224fb361bae19941c906e1.png)
What's funny is the guys waxing about the old days aren't going back very far. Porsches used to be turbo, on-off switched beasts.
I think my favorite comments are that it "is not Motorsport." The shared component list of 3RS and RSR is very short. Does "is not Motorsport" translate to "not on list"?
These are street cars and this thing is going to be a blast!
Pete, did you drive the new Turbo S ? I could barely discern any lag in this latest engine/PDK set up, even the transition from off boost to on boost is amazing just a very linear curve with no real step up..... The RS I'm sure will be different with its CR and bigger turbos but I suspect it will be relatively lagless if the latest ttS is anything to go by.
It will only need 7.1PSI boost to match the compression ratio of the mill in the .2GT3, which is not a lot. Its interesting to note the 488GTB runs a static ratio of 9.4:1 and the newer 3l 9A2 has a static ratio of 10:1
. So at first blush it looks a little dated.
Static compression ratios of turbo charged cars
WRX STI 8.2:1
RS275 8.6:1
A45AMG 8.6:1
570S 8.7:1
GT2RS 9:1
EVOX 9:1
488GTB 9.4:1
GolfR 9.6:1
991.2S 10:1
M4GTS 10.2:1
AMG GT S 10.5:1
720S 10.5:1
WRX STI 8.2:1
RS275 8.6:1
A45AMG 8.6:1
570S 8.7:1
GT2RS 9:1
EVOX 9:1
488GTB 9.4:1
GolfR 9.6:1
991.2S 10:1
M4GTS 10.2:1
AMG GT S 10.5:1
720S 10.5:1
IMO, it is the test engine for switching the RSR to turbo. Why do the factory testing when a bunch of people will pay you $300k+ to do it for you. They needed to be under 4L displacement as per the regs.
It's the same playbook as the 991.1 GT3.
The reviews aren't even out yet but it feels like people are looking for reasons to hate this car and justify their decision to wait for the .2 GT3 RS.
