How 'special' is the new GT2RS engine really?
Obviously there are many special bits and lightweight pieces on this car, but how special is the engine?? Is it simply a turbo s motor with bigger turbos or are the internals beefed up, higher tech materials etc? Hard to tell from Porsche's official website. I was a little surprised that it is 'only' 3.8L and for a motorsports/race engine only revs to about 7K. Thoughts?
Jim
Jim
you want an answer from the engineering department or the marketing department ?
Location: The way to hell is paved by good intentions “Wenn ich Purist höre...entsichere ich meinen Browning” "Myths are fuel for marketing (and nowadays for flippers too,,,)" time to time is not sufficient to be a saint, you must be also an Hero
Is a damn turbo s in a carbon suite
delete
is a good question -
Just about every turbo owner I have met over the last 10 years, has 'modded' the engine to a ridiculous amount of power. Is this engine really that much better? I don't have a good answer - curious as well.
It basically a turbo S engine turned up to 11. Same displacement with bigger turbos and water injection like BMW uses in the M4 GTS. I am sure there is more to it but this is my understanding. I wish they did make it higher revving to differentiate it from the turbo S motor. McLaren and Ferrari have much higher redlines but they are V8's with flat plane cranks. Maybe some other more knowledgeable person can elaborate.
GT3 player par excellence
anything with RS attached to it is special, in reality or in dream, doesn't matter.
the mkt will always support it.
while special, my wallet can't carry the wt. so not for me
The spec show a 9.0:1 compression ratio compared to the tttS 9.8:1 this indicates different pistons which are no doubt stronger, peak power is at 7000rpm which is higher up than ttS so likely different cams, rods are likely specific also.....
This seems to be a hotted up ttS motor, I don't think this is a bad thing the latest 580PS ttS motor has evolved from the original 997.2 turbo and is a nice motor, very free revving and screams well at the top end when in nutter mode. The RS must surely have more lag (the ttS has none) with its bigger turbos and lower CR but I'll bet they have really minimised it.
200-300kph is quoted at 13.8s which with a CdA of 0.749 illustrates a very healthy power curve.
Jim
Jim
Originally Posted by GrantG
Nope, not water injection. Just water sprayers on the outside of the intercoolers, like Subaru and Mitsubishi used 15 years ago.
Chances that the turbos are different. They might not do the VTG nonsense. Accepting higher fuel usage also allows them to keep the turbos spooled up covering more periods.
Did they publish a torque curve already?
Either the PDK was the bottleneck or they wanted to give a sportier feel with a strong surge to redline (although slower than allowing the engine to make more midrange torque than the Turbo S).
