can a damaged block be repaired?
Old 02-22-2017, 11:41 AM
  #31
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,183 Likes on 1,233 Posts
Originally Posted by Jerry Feather
I also suggest that there is absolutely no particular procedure in the casting process to keep the silicon from either settling or floating during the process, and certainly no particular handling of the casting between the time it is poured and it sets. Where did you come up with all of that?
You need to research how the Vega block was cast compared to the Porsche / Mercedes engines:
https://rennlist.com/forums/928-foru...l#post13256866
Originally Posted by Vilhuer
Reason why alusil worked better in Porsche engines than on Vega motor was casting process. Problem in Vega was that when block was cast two materials would not stay uniformly mixed until casting solidified. This lead to uneven casting where silicone wasn't present in needed quntity on some spots. Result was same as what happens when overbored 928 cylinder walls aren't properly done.
Famous Cosworth DFV 3L F1 V8 engine had solved this problem already years before Vega problems by turning casting upside down during its cool down period. This made sure material distribution was uniform in areas where it mattered. Porsche or more likely actually Mahle solved same problem by controling how casting cooled down. Same process has been used in many other engines. More info about the process is available for example in this document.
https://trid.trb.org/view.aspx?id=197260
http://papers.sae.org/830003/
http://www.w124performance.com/docs/...nditioning.pdf
Old 02-22-2017, 12:26 PM
  #32
FredR
FredR's Avatar
... everything I can find on the internet says that Alusil is an alloy. t?
There is already welding rod available with silicon in it, but not as much as the 928 block. The Block has 30 percent silicon, and 4047 welding rod has only 12 or 13 percent silicon.
Jerry,
I was intrigued by some of the comments in this thread so did a Google on it and found an interesting article in Wkipedia. Alusil is indeed referred to as a "hypereutectic alloy" of aluminium and silicon with 78% aluminium and 17% silicon - no reference to what the remaining elements are. I am familiar with the term hypereutectic but absolutely no memory whatsoever of what it means other that it is a reference to the condition of the crystalline structure.
The alloy was conceived in 1927 and surprise surprise it was developed by Kolbenschmidt. What was a bit more surprising is that not many engines have been made with this stuff and the ones that are were made by Porsche, Audi, BMW and MB with the others lagging behind Porsche by quite a number of years. The first Porsche with Alusil was the 928 and by a few years or so it seems.
Welding this stuff should not be a problem in terms of structural integrity but whether or not it can be welded and leave a surface that can be etched to replicate the performance of the cast material is doubtless another matter altogether. I suspect the problem is not that it cannot be done but rather there is not the economic return to research/develop weld procedure specifications that can generate the requistite mechanical properties to support internal combustion mechanics.
Even more interesting was the statement that BMW migrated from nikasil because of corrosion issues caused by sulphur content in fuel and that was in 1996!
Rgds
Fred
Old 02-22-2017, 12:40 PM
  #33
Strosek Ultra
Strosek Ultra's Avatar
Originally Posted by GregBBRD
This is the process that I was familiar with (new actually seen one, but had heard about) and figured that this was going to be the sleeves that KS offered.
Looking at the OD and ID of the sleeves you originally posted about, those sleeves appear to be entire cylinders.
Are you aware of where the thin sleeves can be obtained?
As said it is a factory exchange engine. I do not know if or where the thin sleeves can be obtained. Probably it is Porsche made sleeves for repair purpose.
The upper part of the sleeves is flanged (OD 108 mm). You have to get a KS blank sleeve part no. 89 880 190 and machine the sleeve yourself or have someone to make it for you.
http://www.pierburg-service.de/ximag...199_en_web.pdf
Åke
Old 02-22-2017, 12:42 PM
  #34
hacker-pschorr
Mercedes hit the market first with the 1977 450SL M116 engine.
Old 02-22-2017, 12:50 PM
  #35
Strosek Ultra
Jerry,
Rgds
Fred
BMW had problems in certain markets like North America and Australia due to high levels of sulfur in the fuel.
Åke
Old 02-22-2017, 12:58 PM
  #36
hacker-pschorr
So did Jaguar.
I've talked to some Jaguar guru's who cannot believe my mothers 97 XK has close to 200k miles on the original engine (never even taken apart to update the cam chains). It was delivered to Appleton, WI and spent it's life in NE Wisconsin where we have sulfur free (or reduced) fuels compared to places like Chicago where Nikasil issues are more common.
Old 02-22-2017, 01:03 PM
  #37
Strosek Ultra
Jerry, in this particular case I would grind out and weld the crack in the cylinder. Bore out the cylinder and install a thin wall alusil sleeve (OD 104mm, flange OD 108mm). Bore and hone the cylinder to specs. However as Mr. Brown say it is always a risk involved in welding the engine block. I had a block welded once by a very skilled welder and it seems to work fine. It was a crack at the front main bearing. Following the welding I had to do a lot of machining like flycutting of the girdle mating surface on the block, inline boring of the mains and machining out and installing a bush at the oil pump housing.
Åke
Old 02-22-2017, 02:59 PM
  #38
FredR
FredR's Avatar
Indeed, I thought they started with the 117 series engines but apparently they changed the 116 series to aluminium albeit in 1978 according to the reference I picked up.
Never been too interested in MB with their generally staid designs. I loved my last UK based car - 1986 BMW 535 straight six [cast iron block] - that was a lovely motor in its day and still relatively new when I owned it back in 1989 [they were very cheap s/h in the UK].
Rgds
Fred
Old 02-23-2017, 03:52 AM
  #39
Strosek Ultra
Rgds
Fred
Fred, your interest in MB will increase with age. As they say in Germany, "Mercedes Benz ist ein Auto für alte Männer" which for you guys not familiar with the German language means that MB is a car for older men.
Åke
Old 02-23-2017, 05:20 AM
  #40
FredR
FredR's Avatar
Åke
Åke,
This is very true. At the current rate of progress reckon that by the time I reach 100 I may well want one!
There are only two MB models that interested me, one being the Gullwing [and we know how unobtainable those are] and the 560 SEC of the 80's vintage. After that I feel MB lost their way somewhat when they went into the mass market. They scoffed at Lexus when that was launched back in 1990 and ended up eating humble pie. Nice cars of course but questionable value proposition. Much preferred BMW and then of course Porsche when I had some $$$'s to join the club. Even Porsche's are generally ugly cars [928 excepted of course] but once you drive them they are something else. The Cayenne is ugly as sin but what a drive- especially when you have 520 BHP and a shed load of torque on tap. The Panamera is real ugly duck but again awesome when you drive one.
I do not see a MB in my immediate future but who knows?
Rgds
Fred
Old 02-23-2017, 11:19 AM
  #41
Imo000
Captain Obvious
Super User
Imo000's Avatar
Try out one of the big engined AMG models and report back.
Old 02-23-2017, 11:52 AM
  #42
ptuomov
ptuomov's Avatar
Or three.
Old 02-23-2017, 03:55 PM
  #43
Strosek Ultra
For some unknown reasons Tuomo, which is quite a young guy, do drive a Mercedes. Maybe he has some comments about his choice of car? Myself I qualify when it come to age and I have the means but I have realized I have too many cars and too many ongoing projects in order to find time for one more car like a MB.
Åke
Old 02-23-2017, 04:58 PM
  #44
jcorenman
jcorenman's Avatar
Or a big-engined 928 ...
Old 02-23-2017, 05:05 PM
  #45
hacker-pschorr
Quick Reply: can a damaged block be repaired?
