525 HP 951 - Jalopnik
Administrator - "Tyson"
Basic Sponsor
525hp 2.5L 951, that it's called this
Professional Hoon
The mods list is in the comments
I call Bull S**t
The LR Sport turbo?
Well this is awkward. 375rwhp is LR claimed limit of their "sport turbo"
Lindsey Racing Solid Cam Package
Lindsey Racing Solid Lifter Camshaft
Cross Drilled Crank
JE Pistons 8.5:1 Compression
Nicom coating of cylinder walls
Level 1 Head Kit
Racing Springs w/ moly retainers
3" Downpipe
4" Lindsey Racing Exhaust system
Dual Port Wastegate
3" Lindsey Racing “Sport” Turbo
Lindsey Racing Chipset
Lindsey Tune Up Kit
Spec Stage III Clutch w/ Hybrid disc
Stage II intercooler
Manual Boost Control
Stage 2 MAF Kit
Mafterburner MAF control kit
UEGO 2000 Wide Band Oxygen Sensor Kit
Cross Drilled Crank
Level 1 Head Kit
3" Downpipe
Dual Port Wastegate
Lindsey Tune Up Kit
Stage 2 MAF Kit
The LR Sport turbo?
Originally Posted by V2Rocket
Man JBrown would be pissed to find that
Basic Sponsor
Yeah I'm sure 900hp from a 2.5L are possible especially with this special pipe
This BMW's 1.5L engine can produce 1500hp. But only if you pee on it.
Basic Sponsor
For comparison
My car
LR 3.0L
5 inch exhaust
Mafterburner 72lbs injectors at the time of Dyno.....now M-tune 80lbs injectors
Level 3 Head with HV exhaust valves
Solid lifters and a more aggressive cam than this one I am positive because my cam would be too aggressive for a level I head.
Super 75 with .58 T4 hot housing and 3 inch downpipe
JE pistons 8:1
Pauter connecting rods
Knife edge crank, cross drilled...full lighten
Full alum pressure plate with Full Metallic clutch disk and Fidanza flywheel
Extrude hone intake....traded my stock one for the polished Turbo S one that has more vac ports and happened to be extrude honed
Under drive pulleys with AC delete
Stage 2 intercooler
My turbo and exhaust is 2000F ceramic coated
HV pump with -8An fuel lines
Dual port wastegate
I put down using Petro Canada 94 octane fuel:
418hp and 444ft/lbs torque at 15lbs boost
Dyno day with Porsche club with a bunch of other cars:
All of the cars about 20 (Porsche's, 1 Ferrari 355 challenge car, 1 Toyota truck with supercharger) that day had hp numbers within the ball park of what they should have been....no one was there to bulls@#t numbers
So I have 20% more displacement and it has over 100hp more than me.
LOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My car
LR 3.0L
5 inch exhaust
JE pistons 8:1
Stage 2 intercooler
Dual port wastegate
