1978 928 at public auction in Maryland tomorrow
#76
"THE BAD: ??
1. Coolant was very low and only seemed to be water. filled it with only water again and got the "Low coolant" light to go off, but the temperature continued to rise. Perhaps a bubble in the system?... I am not sure where the bleeder valve is and will look in the A.M."
Old trick in the Auto Auction World: If there's a water system leak, drain the anti-freeze and replace with plain water. You can smell an anti-freeze leak but you can't smell water.
#78
#79
As said before I would be checking that oil closely for any signs of water in the oil.
#80
What's amazing to me is they found really early euro ones to replace the originals...Unless they "filled" the euro side marker area before putting the euro side markers in front of the wheels? A little odd but with these cars almost 40 years old who know.
Low coolant warning has gone off too. I let it idle in the driveway and the fans eventually came on. Slow drip from the drivers side front. I suspect a side tank leak.
**Where does the temp guage tend to sit on others cars when letting it idle until the fans come on?
#81
The temp gauges are notoriously "individualistic" (best word I could think of). They are good at telling you "trends" (if it starts going up, pay attention), but some cars run at the bottom line, others run at the top white line. With the exact same measured temp.
If you want a good idea what the temps actually are, get an IR gun and take real temps at the thermo outlet & water bridge.
#82
#83
#90
Beautiful car. The condition of those rear quarters make it look like it lived an indoor life when not on the road.
will
