996 Forum 1999-2005
Front NT01s won't fit
Old 06-17-2016, 11:06 PM
Slakker
Slakker's Avatar
Not having luck getting my front NT01s to fit on my track car. They work fine on my DD but it's about an 1.5" higher off the ground. The front wheel is running against the coilover. If I use a 6mm spacer I have lying around then it rubs the front when I turn instead. Any suggestions other than running the z214s that work fine?
Old 06-17-2016, 11:23 PM
Slakker
Slakker's Avatar
Nt01 wheels are about 6mm different in offset so the spacers were perfect. But they are 20mm wider than the z214 in the same size. So annoying.
Z214 - 245s measure 240mm
NT01 - 245s measure 260mm
Old 06-17-2016, 11:35 PM
911TTCAB
911TTCAB's Avatar
245-40-18 work great in the front on my car. 108 mm front height. 2.25 camber
Old 06-18-2016, 12:15 AM
Slakker
Slakker's Avatar
Ya, I'm missing something. It's got the same ride as yours which is the same as my silver one that these work great on.
So does driving on z214s to and from Autocross count as a heat cycle each way?
Old 06-18-2016, 12:54 AM
vandersmith
vandersmith's Avatar
What tire size? What wheels? What offsets?
Me: 235/40/18 - 18x9 - 53ET +7mm Spacer
Work fine
Old 06-18-2016, 01:06 AM
Slakker
Slakker's Avatar
Originally Posted by vandersmith
What tire size? What wheels? What offsets? Me: 235/40/18 - 18x9 - 53ET +7mm Spacer Work fine
My wheels are 18x9 with similar offset (it's not marked) but I have 245/40/18 tires.
Old 06-18-2016, 01:25 AM
jj1
jj1's Avatar
You might have too much caster.
Old 06-18-2016, 01:26 AM
vandersmith
www.rimsntires.com
Old 06-18-2016, 01:33 AM
Slakker
Slakker's Avatar
I didn't get the specs on caster but camber is -3.2 and it is only -1.8 on my silver one.
Ya, I think the 235 would give be me the extra little Bit of clearance.
Old 06-18-2016, 02:17 AM
jj1
jj1's Avatar
Does it have split control arms with more than 10mm of shim? If it does, and there is not an adjustable puck or threaded thrust arm, I bet it has too much caster.
Old 06-18-2016, 09:00 AM
Slakker
Slakker's Avatar
It does have at least 10mm of shim on the GT3 LCAs.
Ok, got it. So the Camber has them rubbing against the coilovers and when I use spacers to compensate the caster has them rubbing against the front.
So is an adjustable thrust arm bushing the best solution? Will that require another corner balance or just alignment?
Old 06-18-2016, 12:08 PM
jj1
jj1's Avatar
I would say an adjustable thrust arm is the best solution but adjustable pucks are cheaper and will work. Technically you can't really adj camber/ caster without changing your CB a bit. But theres a more than good chance you wouldn't notice the difference if you just did alignment.
Quick Reply: Front NT01s won't fit
