AWE Tuning 991S/4S/GTS Exhaust Video & Special Pricing by TAG Motorsports
Old 04-03-2016, 05:48 PM
  #46
Larry Cable
Larry Cable's Avatar
Received 3,604 Likes on 2,343 Posts
stuck, I just dont see how its possible to safely disconnect the factory vacuum line w/o removing the back bumper and heat shielding...
Old 04-03-2016, 06:49 PM
  #47
Larry Cable
final score - larry nil, factory vacuum line 1... I just dont see how its possible to
disconnect it safely w/o removing the bumper and heat shielding, so I've put
everything back to stock ...
Old 04-04-2016, 12:56 AM
  #48
hlvg
hlvg's Avatar
Bummer - if correct, that means having a shop do it (for me at least).
Old 04-04-2016, 11:55 AM
  #49
cajerseyboy
cajerseyboy's Avatar
Sorry to hear about this Larry. I would have thought it would be a straight forward install with what Fastdiablo said. Keep us posted.
Old 04-04-2016, 11:57 AM
  #50
Larry Cable
he took the bumper and heat shield off... AFIAK
Old 04-04-2016, 12:16 PM
  #51
Larry Cable
well according to others it appears possible:
http://www.6speedonline.com/forums/9...ournal-15.html
I personally do not see how it is possible to do it safely; one end is 'hidden'
above and behind the exhaust itself, so its difficult to get your hands into
the space, I tried to pull it off the actuator end to no avail, its easier to see
the other end which attaches to the engine, but both ends are I believe
crimped on ...
I ended up restoring the car to stock ... I guess if I want this I am going to
have to take the bumper and heat shielding off ... which is a major PITA
and will add a couple of hours to the task... (Ive done this already when I
installed BMC filters)
Old 04-05-2016, 12:51 PM
  #52
c_Gio
c_Gio's Avatar
crimped on ...
Hmm interesting point. How often do we replace the BMC? Maybe next time = install AWE at same time? Is it every 10k miles?
Old 04-05-2016, 01:21 PM
  #53
Larry Cable
I'm psyching myself up to do this ... Ive had the bumper off before when I installed the BMC's ... but it will add quite a bit of time to the install, it should
however make the task much simpler since it will offer much greater access
to the exhaust...
Old 04-06-2016, 08:51 PM
  #54
Larry Cable
Default In the spirit of Robert The Bruce... (part I)
We Scots are not easily deterred either by defeat at the hands of the English (c.f: http://www.educationscotland.gov.uk/...ider/index.asp) or by a simple
vacuum line ...
let the install begin: step 1 (remove the back of the car)
took the bumper off, (hardest part is disconnecting the lic plate light) then
removed the rear impact bar and heat shield, voila! an exhaust laid bare for
all to see and work on...
took me 1 hour which included cleaning the bumper prior to removal (Griots Waterless car wash and microfibre clothes) and jacking the car ...
Old 04-06-2016, 09:06 PM
  #55
hlvg
hlvg's Avatar
Go Larry, go !!
Hopefully you're taking good notes (even better, a video?) on all the steps and will share with us
Old 04-06-2016, 09:10 PM
  #56
Larry Cable
Go Larry, go !!
you do not need a 1 hour video of either my plumbers crack or the top of my balding head bobbing around - occasionally interrupted by a string of expletives!
Old 04-06-2016, 11:33 PM
  #57
teambell
teambell's Avatar
Larry - How do you like it? Do TELL!!!
Old 04-06-2016, 11:49 PM
  #58
Larry Cable
dont know yet, only got as far as the photo above ... doing the rest tomorrow ...
Old 04-07-2016, 01:15 PM
  #59
Larry Cable
Default part deux....
removed the center section this morning, 20 minutes!
The previously rebellious vacuum line succumbed with little or no resistance ...
Old 04-07-2016, 09:17 PM
  #60
TAGMotorsports
Premium Sponsor
TAGMotorsports's Avatar
Looking good!!!!!!!
TAG MOTORSPORTS
866-793-5490 x1192
web: www.TAGMotorsports.com - email: sales@tagmotorsports.com
Authorized Dealer For: HRE, Vossen, TechArt, AWE, Bilstien, KW, Akrapovic, Capristo, Fabspseed, BBI, Vorsteiner, Milltek, 1016 Industries, BBS, Brembo, GMG, H&R, Pirelli, Michelin, Hankook & more.
TechArt & AWE Tuning's #1 Volume Dealer Nationwide
Quick Reply: AWE Tuning 991S/4S/GTS Exhaust Video & Special Pricing by TAG Motorsports
