AWE Tuning 991S/4S/GTS Exhaust Video & Special Pricing by TAG Motorsports
#61
up until the point that you discover that AWE either cant measure, or are too cheap, to include enough vacuum line to comfortably reach from the t-connector
to the actuator on the drivers side... 15" is *not* long enough! 13.5" for the
passenger side is fine, with some to spare, the drivers side is just not long enough by about 2-3" ...
So instead of wrapping this up, I now have to trot off to Kragen to get some hose, then hopefully find some Oetiker "9" 2-ear hose clamps ...
*not* TAG's fault whatsoever ...
Update the drivers side vacuum actuator when installed, had its
vacuum line connector pointing towards the front of the car, disconnecting
the actuator and rotating it clockwise 120 degrees allowed the 15" hose to attach...
#62
#63
a longer hose to reach the drivers side ...
so I am awaiting that from AWE before I complete the install.
#64
Do you think that's why you've had to pull off the rear bumper as well (while others said they didn't have to)?
#65
Larry - this is turning into quite a project for you! Sorry to hear.
#66
drivers side 15" line is too short...
my "solution" was to rotate the actuator 120 clockwise to narrow the distance
between the actuator and engine, thus enabling the line to work, AWE rightly
expressed concern that this might expose the line to additional heat from the
exhaust, so they are overnighting a new hose and clips to me to resolve the
problem (which fastdiablo also encountered previously when doing his DIY install)
So, I will remove the exhaust (again) and return the actuator to its original
position and re-attache the longer line.
FYI to any GTS owner wanting to install an AWE exhaust ensure that you have this longer line before commencing the install
#68
#70
They should pay you for debugging this for them!
#71
Uh, I already debugged it with them and am none too pleased that Larry is having the exact same flipping issue AND my exhaust was shipped with short hoses and get this.. ZIP TIES compared to Larry's kit which had the metal hose clamp/clips. Like what, they were out of proper parts when my $2500 exhaust was shipped so they threw in zip ties? And btw, the story I got from AWE about the hose being short was that the instructions were based on a preproduction unit and the actual valve actuators were higher end units with nipples that pointed towards the front of the car. Now the story is its the car's fault because it's a GTS not a Carerra S. So now I'm driving around in 150k car with zip ties holding vacuum hoses on.
#72
#73
#75
AWE have been very responsive, they are shipping me a new line and clamps so hopefully I'll be done this weekend and will let them know just how long that
line needs to be to work on the GTS ... so hopefully other GTS owners wont
have the same issue that fastdiablo and I have had ...
apart from this issue, the product is high quality and I cant wait to put the car
back together, wait for the rain to stop, and head out onto the open rad!
