FS: Mid Rise Scissor Lift w/6,000 lbs capacity
I'm selling my mid rise scissor lift. Purchased in 2012. Ideal for all maintenance jobs. Perfect for engine drops (rear brace modified for 911s), oil changes, tire swaps, and just about anything else you can think of. Has usual patina from use, but no leaks or issues. Selling because I'm putting in a 4 post lift. And yes you can have the wicked, customized, 2 x 10 ramps
It weighs close to 800lbs, so local pick-up only. I cannot deliver.
Asking $1,750
Lifting Capacity: 6000 lbs
Portable Motor Cart Serves As Tow
Handle To Easily Move Lift From One Bay To Another
Adjustable Arm Assemblies, with variable height lifting pads
Safety Lock Bar With Multiple Lock Positions
Overall Width: 40" / 1016mm
Overall Length: 81" / 2057mm
Lifting Height: 48" - 53" / 1219mm - 1346mm
Minimum Pad Height: 4-3/4" / 121mm
110Volt Power Unit
Asking $1,750
110Volt Power Unit
Buddy of mine just bought this exact same lift brand new. It's a great lift. I have a 4 poster from the same company. One thing to note, the red and black caps need to be switched on the reservoir. The black has a vent, the red is a solid plug used for transport. I made the same mistake with mine.
This is priced well, someone is going to get a good deal.
