Garage Porn
#36
Wow, that's sweet! Congrats
Question about these types of lifts (4post); how do you take the wheels off to do any servicing? Does it have adapters? Or is it for storage and oil changes only?
#37
Jakob,
You can get hydraulic jack pumps that slide on the inner part of the direct lift. They are an additional $695.00 each (you need 2, for front and back of car if wanted)
I opted out till next year...need more funds
Jeff
Jeff
#38
The wheels just insert and cotter pins hold them in place.
You don't leave the wheels on all the time as the ramps won't lover all the way to the ground.
They're just for moving the lift.
Direct Lift is the 2nd example.
#39
I posted many photos of the assembly previously.
Don't know if I'd ever get2 of them because how often do you need all 4 wheels off the ground?
And if you do, simply lift one end, put in jack stands and then slide the whole jack to the other end.
#40
I agree with you, not a huge need for two scissor jacks. I will most likely just get 1 of the scissor jacks next spring. I could have really used it when I was working on my car for a month this summer.
Jeff
Jeff
#41
#42
1st you raise the lift about a foot.
http://www.youtube.com/watch?v=u7VCCJeTSZA
#43
^^^ optional scissor jack $695.00
Check out the website, optional scissor jack on the right side of website.
http://www.directlift.ca/pro-park-8.htm
#44
