Porsche Mechanic Recommendation
Old Feb 25, 2014 | 12:06 PM
2001Porsche911's Avatar
2001Porsche911
Default Porsche Mechanic Recommendation
Hi everyone,
I have a 2001 Porsche 996 tiptronic which i have had the following two error codes for the last year:
P0740- Solenoid Valve- Torque conv. clutch
P0710 Transmission Temperature Sensor
I usually do all my repair work/maintenance myself (changed water pump, wheel bearings, brakes, oil pressure sensors, etc) but I am having a hard time diagnosing this problem, mostly due to the fact that I don't have a lift in my garage and its very hard to work under the car with just jack stands.
I'm thinking of just taking the car to a Porsche mechanic (Not the dealer) to have them look at this, can anyone recommend a decent shop that will not charge an arm and a leg to look into this?
Thanks,
Old Feb 25, 2014 | 12:27 PM
myw's Avatar
myw
eu autoworks / hunter motorsports. they seem to be the trusted gta p-car technicians.
Old Feb 25, 2014 | 12:55 PM
REDTURBO's Avatar
REDTURBO
Liam at Keltech is fantastic with Porsches!
www.keltechperformance.com
Located in Markham, he will fix your CEL issues......
Old Feb 25, 2014 | 01:50 PM
P0rsch3F113's Avatar
P0rsch3F113
Auto Select in Newmarket.
Old Feb 25, 2014 | 01:53 PM
CamsPorsche's Avatar
CamsPorsche
another for EU autowerks
Old Feb 25, 2014 | 06:41 PM
996_North's Avatar
996_North
I have used Liam @ Keltech when he was in the west end of town, and Hunter more recently. Both great guys.
Old Feb 25, 2014 | 07:22 PM
Ontario997's Avatar
Ontario997
8th Gear
Brent Hunter. Great guy.
Old Feb 25, 2014 | 08:05 PM
myw's Avatar
myw
https://rennlist.com/forums/rennlist...ml#post8977414
Old Feb 25, 2014 | 08:48 PM
StanThePorscheFan's Avatar
StanThePorscheFan
Because you asked for great tech AND a reasonable price, I would go to Brent @ Hunter Motorsports. If he spends half hour on your car then thats all you will pay for. Not saying its any different anywhere else, just that Brent was always nice to me and my brother. I even got a free PPI once.
Old Feb 25, 2014 | 11:19 PM
2001Porsche911
Thanks for all the recommendations, I will look into each of them!
Old Feb 27, 2014 | 10:40 AM
Torontoworker's Avatar
Torontoworker
As far as the codes: The torque converter issue is a known issue with 996 Tip's. That's the bad part. The upside to this issue is that it mainly affects the automatic operation in the 'coast' down mode. I've had a solenoid torque converter code for years and it isn't an issue if your like me that uses it in manual 99% of the time. Generally the issue is a faulty solenoid that controls the operation. If you have a code for the converter itself... along with the temp sensor - I would want to check the fluid level right away. Its a goofy procedure to change the fluid and costly - but the color and smell of the fluid can tell the mechanic a lot about the condition of the transmission. Its rare to have a convertor failure without other issues with this transmission... It may be time for an R&R. Brent uses a specialist in Kitchener for this.
Good luck. I used Hunter and Mantis for work - either are great.
Old Feb 27, 2014 | 10:59 AM
jumper5836's Avatar
jumper5836
Depends, on my Cayenne TT the torque converter seal start leaking. If caught before it runs dry it won't do any harm to the transmission. We never did get a temp sensor warning but I have gotten it after it was fixed while at the track after pushing it for 30 mins.
Old Feb 27, 2014 | 02:38 PM
LPhieE's Avatar
LPhieE
Jack at Gtek (east end) takes care of my car. Competent work at a competitive rate.
Old Feb 27, 2014 | 11:27 PM
2001Porsche911
I didn't know it was a known issue. What happens with me is it drives perfect in auto or manual mode but on a few rare occasions after driving for over 1.5hrs it will go into the reduced driving program (4 and D flash) but the car drives perfect still, no difference at all in the way it drives or shifts, but the flashing just scares me lol. Once i park the car and come back the next day, usually it is back to normal. The check engine light stays on though until it is cleared.
I will get the fluid level checked first thing!
