GTA 911turbo alignment and lowering?
My car would benefit from an alignment (it has been awhile and the steering wheel is very slightly off center, and I just put new rubber on it), but I wouldnt mind lowering it a bit too.
911 turbo with PSS9s (with 18s).
Questions:
1) Should I lower it to my liking then bring it for an alignment?
2) Where should I bring it?
Questions:
Pocket Sand
You should lower it first before alignment for best results.
bestline autotech is where I go. up by 400/7
Sportscar boutique is closer to the east end if you're in that part of town (yonge & finch ish area)
Both run race cars and know how to set up a 996 for street or track.
I know the crew and Sports Car Boutique and can recommend them.
I suggest you have them set the ride height and do the alignment at the same time for best results.
Hunter Motorsports in Mississauga did my PSS10 install and alignment. Fantastic job, its like driving a whole new car.
