how to clean injectors?
Has anybody ever effectively cleaned fuel injectors? How did you do it?
From what I've read soaking them in carb cleaner seems to be par for the course, but would like to hear from someone who's done it.
Thanks!
Thanks!
I recently cleaned mine, leaking was reduced but not compleetly, I ended up buying a new set.
Tools;
-Compressor
-Low current 12v power supply
-Injector safe carburetor cleaner
-Injector socket
-Rubber hose
-Compressed air blower
I basically soaked them over night, I then connected them to a 12v power source with a momentary switch and forced compressed air through them. I was actually able to get some carburetor cleaner in the compressed air hose, the cleaner was then forced through the injector while it was being opened by pressing the switch.
http://www.rowand.net/Shop/Tech/DIYF...orCleaning.htm
Tools;
-Compressor
-Injector socket
-Rubber hose
Captain Obvious
Super User
Super User
Injectors have moving parts and are a wearable item. You can send them out to get it cleaned, painted and the filter, pintle cap and O ring changed, but internally it still be just as worn.
Thanks for the help guys... I'll take them over the weekend and see if they're gone or not....
Part of me hopes they're not too worn and I can get them cleaned... the other part of me hopes they're destroyed so that I can be confident I've found what is causing my car to have zero power.
Ice, no I haven't, is it easy to do? I never even thought of it good suggestion.
I ended up cleaning my MAF yesterday because I thought maybe the oil on my air filter (I had recently cleaned it) might have messed with it... What a difference!!!
Team Owner
you have an oil based air filter ? those are typically bad news .. Kand N and the like are known to cause MAF contamination . If your car was designed for a good old fashioned air filter go back to it.
In other news, ice you'll be proud I drove my first 915 transmission car last night! Grandpa's friend came by their property with his '77 911S, which had a 3.2 in it but still the original transmission... we went for a little drive and after awhile he pulled over and told me to give 'er a go... nervously I did (knowing about the "money shift") but I took her very easy and had no problem! Once the gearbox was warmed up she shifted fairly nicely, 2nd gave a bit of trouble but I definitely enjoyed it!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I've seen definite improvements in the poor little car since starting to address some maintenance items this fall... maybe she'll see 400k after all!
I think the biggest help was giving her a good wash on Saturday... it was very happy aftewards!
Team Owner
yeah second its typical . that is why you need the "pregnant pause " on a 915 between 1st and second . and downshifting into second can sometimes be challenging if the synchros are starting to go .. lke anything else it just takes practice.
Thanks for the advice Mark, I will definitely take the injector tips into consideration when I get to that! Good to know about the dismantler, I think thats where I'm headed to find a new resonator!
How are things? Haven't see you at a GTG this summer!
Thanks Jon, I didn't think anyone noticed, Saturdays in the summer aren't good for me, see you at a GTG soon.
