OT - New garage floor
Subscribe
Jan 29, 2011 | 09:36 AM
Do you have any contcat info on the guy in Detroit? I live in Windsor, very short drive for me.
Reply 0
Jan 29, 2011 | 05:22 PM
Those random "spots/dots" on your expoxy floor, are they part of the epoxy? Can you pick and choose the colour?
Reply 0
Jan 29, 2011 | 08:21 PM
Quote: So, my 7 year old house has a sinking garage floor. I had an home inspector in last summer as I was getting some mold and on the wall which is a result of the floor pulling away from the wall and the moisture in the ground evaporating. I
have had a bunch of quotes and it looks like $4,500 - $5,500. So funds that would have turned into a set of HRE P40's for the 997 now will simply result in some flat evened color concrete.
Since I am into this for about $5K I am wondering if there is anything else I should consider doing to it while I am at it? I was thinking about colouring it, or perhaps even getting it stamped. This time I may even pin it to the foundation walls so the damn thing wont sink again.
You guys have any other idea's?
Out of curiosity and because I'll need to redo my garage floor at some point, what is the square footage you are re-doing?
Reply 0
Jan 31, 2011 | 04:44 PM
Quote: Out of curiosity and because I'll need to redo my garage floor at some point, what is the square footage you are re-doing?
I believe it is approx 19' by 19', a standard 2 car regular depth garage.
Reply 0
Feb 6, 2011 | 06:38 PM
Quote: Do you have any contcat info on the guy in Detroit? I live in Windsor, very short drive for me.
Sorry for the late respond was away for a week and just got back late last night, please check your PM
Reply 0
Feb 6, 2011 | 06:42 PM
Quote: Those random "spots/dots" on your expoxy floor, are they part of the epoxy? Can you pick and choose the colour?
Sorry for the late respond was away for a week and just got back late last night.
Those are color chips that you sprinkle on the epoxy right after you apply (or a helper to sprinkle on).
http://www.originalcolorchips.com/
You can find more info from this forum:
http://www.garagejournal.com/forum/f...splay.php?f=20
You need a top coat (clear coat) for UV protection especially when you add color chips.
Reply 0
Feb 6, 2011 | 09:10 PM
Quote: Sure, not a problem....
Great....I'll PM you when the weather warms up, I'm located 9th line #7
Reply 0
Feb 6, 2011 | 10:16 PM
I'm looking at a 2000 sq/ft shop and in preparation of a budget checked out a couple of options. First was a commercial outfit who can polish and seal or epoxy. The polish and seal is almost $6gs, the epoxy almost $4gs'. Then I found this DIY at $835 US.
http://ucoatit.com/pgs/main.htm
Reply 0
Explore
Feb 6, 2011 | 10:27 PM
Quote: I believe it is approx 19' by 19', a standard 2 car regular depth garage.
19x19... man I'm jealous!!!!
I just (7 months) build myself a tiny garage 1 car + 1 bike, got another car in dusty condo parking and another on the street.
I ended up going with epoxy as well (but skipped the flakes).
However just a heads-up, it's not possible to get the epoxy tinted to a specific color (I wanted to match the darkish-grey exterior of my house, no go).
Don't know what kind of doors you've got now but if you're going with an overhaul of your garage ya might want to consider changing your garage doors for aluminum and glass, I absolutely love mine!
Cheers,
Sid.
Reply 0
Feb 6, 2011 | 11:31 PM
Quote: Great....I'll PM you when the weather warms up, I'm located 9th line #7
Sure, we are just minutes away (I'm in Greensborough)!
Reply 0
Feb 8, 2011 | 03:20 AM
Quote: Sorry for the late respond was away for a week and just got back late last night.
No problem. Thanks for the answer!
Reply 0
Feb 8, 2011 | 11:09 AM
I'd consider 2 things even though you may not use them right away.
1. install the plastic pipes for radiant floor heating and cap them for now. you can do this yourself to save lots of cash. its cheap and easy. Pipe is not expensive. I wish I had done this when I poured my garage.
2. indent a portion to fit a scissor lift in the future.
Paul
Reply 0
Feb 8, 2011 | 12:05 PM
Quote: An idea I had was if I could lower the floor of my garage by about 1 foot or two so I can fit a four post lift and put two cars in with ample clearance. I'm guessing I would have to re-grade my driveway as well. Does anyone know if this can be done at a reasonable cost and will it affect the structure of the house?
i'd think one of the main issues would be to avoid water drainage into the sunken garage.
just as a benchmark, the Ancaster zoning bylaw says the floor elevation of a private garage has to be at least 12 inches above the center line of the street adjacent to the garage.
Reply 0
Feb 14, 2011 | 11:46 PM
This is what I'll be doing to mine hopefully this summer. I am a distributor for a few hi-performance coating systems and can tell you this stuff is one of the best I've seen. They are in eastern canada and should have a distributors there. They are very helpful over the phone just to get some info. Good luck.
http://www.enviroepoxy.com/products.html
Reply 0
Subscribe
