Looking for a proper torque wrench
I bought a dedicated socket for lug nuts. I keep fresh tape wrapped around it. In a hurry you won't scuff up your rims, you can also find it really fast since it is the only socket wrapped in red/duct tape!
Be sure to buy an impact socket. The typical sand cast ones will eventually break if you continually use it... I know from experience. (Cdn Tire sells a great impact set and lately it is always on sale. Buy the one with the manual impact wrench (looks like a broken black screwdriver) and learn how to use it. Once you learn how to use this you will use it everywhere you have a tough nut/bolt to take off. Wonderfull little tool.)
Don't be afraid to rub a little anti-sieze on your lug bolts/nuts from time to time. No, it does not change the torque spec enough to be concerned. No it will not provide lubrication for the nut/bolt to back off. The various combinations of alloys on the rims, nuts, and bolts eventually galls and can be more difficult then rusty bolts to get off. Anti-seize ensures safe, long life, of everything.
If you are a track monkey, carry around extra lug nuts/bolts. I always have a complete spare set on hand, and also keep old ones just in case. You loose one at the track, day over.
Buy the longest torque wrench you can handle. Less grunt means more accuracy and care.
Never loosen your bolts with a torque wrench. Buy a very long breaker bar, with a nice extension, to at least crack the bolts.
I use a combination of a Cdn Tire cordless impact gun, long breaker bar, extensions, speed wrench, and a Cdn tire torque wrench. Changed tires 100s of times at home and the track. My poor pit helper (wife or friend depending) and I can change a set in well under 10 minutes.
Hope this helps somebody...
Ian
Here is a good description of what I was reffering too: http://en.wikipedia.org/wiki/Impact_driver
Best tool in the world to remove those little screws that hold on the brake rotors of a 944!
Money spent on good tools will last a life time...........I personally bought 2 torque wrenches +25 years ago, both are Snap On, one is for smaller fastners in inch pounds the other for bigger up to 100 ft lbs, calibrated every couple of years and always set to zero after use...........they're still perfect.
Agreed... I have some Snap-On line wrenches worth more then a set of tires, and nobody is allowed to borrow, or even touch them. They are the only wrenches I wil use on brake lines. After stripping many fittings over the years, an old mechanic showed me the size difference between a good wrench and a crappy wrench. One thing you are paying for is the accuracy, precision, and fit. For something I will pass onto my son, the price isn't realy an issue.
I have torque wrenches that I use for engines/brakes that never leave the shop, and then I have Torque wrenches I bring to the track. Accuracy on lug nuts/bolts isn't that big a deal despite what people believe. What is important is consistency on all nuts/bolts and making sure they are within area of spec. A little tighter or a bit looser isn't that big a deal.
After spending years in tech line checking people's nuts (LOL!) at PCA events, I realized almost every car torqued to "spec" is different...
Snap-on for the home, Cdn Tire for the track and quick jobs.
Beware to know what kind of nuts/bolts you have on your Porsche wheels.
993 and earlier street cars have aluminum nuts, they should be torqued at 85 lbs.
996 and 997 steel bolts should be torqued at 95 lbs.
If you have aluminum nuts and you track your car often, I highly recommend replacing them with steel nuts for extra strength/torque. They can strip on you over time and loose the torque effectiveness.
The local C_Tire only carries Permatex copper based anti-sieze - while the manual says to use Optimoly-TA which appears to be an aluminum based anti-sieze from what I could find online. Just wondering if there would be any issues with using the copper based stuff ? Or, anyone know where to get Optimoly-TA in Ottawa ???
NEVER had an issue.
