Short Shifter Install
Hey - any of the Sherway Gardens crew have experience installing short shifters?
I bought one and don't have the faciliites in the condo underground parking or the guts/***** to install it myself.![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I could take it to a dealer but this is probably one of the only mods that is simple enough that I could attempt it with some help.
I was wondering if anyone might be willing/able to help me out.
Adam
'08 C4S - Slate Grey
Adam
Adam:
I've got no experience with this but I found a couple of threads for you. Did you order the B&M shifter or the factory Porsche one? By all accounts anything other than the factory kit requires you to make some modifications. The Porshce one, although more $$ is a straight drop in. A project like this would be just the excuse I'd need to buy some new tools for the job!
Good luck,
Cliff
https://rennlist.com/forums/showthre...=short+shifter
https://rennlist.com/forums/997-forum/180906-shift-kits-b-and-b-vs-oem.html
Good luck,
Cliff
If it is not the factory piece I wouldn't install it. You'll potentially have trouble with the tranny down the road that will result in warranty claims being refused by PCCL.
Been der' done dat.
Been der' done dat.
I posted in that second link above and referenced another link with some more info. I've swapped mine, but used the OEM unit to avoid warranty problems and to allow for easy reversal. It's not difficult, but is time consuming the first time if you don't want to scratch things/lose screws/etc. You could easily do it in a parking garage if you had enough light and the right tools. The only thing I can't help with is the B&M requirement to break the OEM cradle to install their shifter.
I had Pfaff tuning install mine. It's about an hour for the install.
Mine is a B&M. I can't see it doing any more damage to the tranny as any other shifter, it's the driver that screws up shifts not the shifter.
Btw B&M makes the OEM shifter, they are the same thing just different colors and packaging.
Adam,
I think that B&M supplies the SSK units for the Porsche factory units. The B&M is significantly cheaper because it requires re-using the cradle from the OE unit. Once it's installed, there won't be any difference in feel between the units. FYI: mine is factory and Greg's is B&M and I'm wiling to bet that they're identical in feel.
I had Pfaff, the dealership, install mine a couple of years ago when the car was in for service. They were about the same price for the install, although I had their shifter installed.
akw.....
I have two 996 clients who installed aftermarket short shifter kits (brand unknown) sometime ago. I have also heard of a third who is not my client.
All 3 had second gear problems down the road, and warranty claims were denied. Whether or not it is the driver's fault, or the shifters, or no one's.......quite frankly it was really quite irrelevant when dealing with PCNA (which is now PCCL for us Canucks) on this issue......their claims were denied outright.
Not speaking as to what the future holds, just telling you what happened in the past from first hand experience. An aftermarket DIY short shifter install will get your warranty refused each and ever time, regardless of how good you are at installing it or shifting IMHO.
Price out a transmission rebuild or replacement first......against the difference of the dealer installing the OEM short shifter kit.....and your aftermarket DIY install. It ain't worth it.
Your gear shift selector is attached to a rod that enters the tranny which moves forward and back and rotates side to side, actuating a tab on that rod which then aligns with indentations on the various gear stacks inside the transmission, which then moves those gear stacks up or down to engage gears on the output shaft. So the motion of the input rod from the shift selector must always remain constant. When you install a short shifter, which in essence only changes the fulcrum of the lever that is the gear shift selector, you are suddenly applying more force to the selector rod, if you move the gear shift with the same force. That simply means more wear and tear on the tranny.
So if you do shift gently (use just the tips of your fingers, rather than ham-fisting it) your tranny and selector rod should suffer no undue wear.
Here's an excellent article, which is where I started when I rebuilt my tranny:
http://auto.howstuffworks.com/transmission3.htm
