Ethanol
Old Nov 14, 2022 | 07:14 PM
jumper5836's Avatar
jumper5836
If shell 91 has ethanol then I guess I should be switching to 93 or 94 and get a new tune.
Old Nov 14, 2022 | 08:08 PM
teal986's Avatar
teal986
Just filled up at the Shell at Appleby and Mainway. Still says no ethanol in v power.
Kinda sucks if they eventually transition as I use v power exclusively for this reason.
Old Nov 14, 2022 | 08:28 PM
Greg981's Avatar
Greg981
My guess is they have already made the transition. I can't see some stations still not having ethanol and others having it. I wouldn't trust those stickers.
Old Nov 14, 2022 | 09:32 PM
Brian 162's Avatar
Brian 162
I was at Costco today filling up my car with premium before putting it away. The non ethanol signs are gone just a 10% ethanol sticker by the regular pump. I'm assuming now the premium gas has ethanol.
Old Nov 14, 2022 | 10:26 PM
reacp911's Avatar
reacp911
Anyone have a graduated cylinder? Its an easy test: just add 100 ml of gas to 20ml of water; shake; if more than 20 ml precipitates out, you have ethanol. Example 25 precipitates out you have 5% ethanol
Old Nov 15, 2022 | 04:34 AM
RDMcG's Avatar
RDMcG
I would love to know what percentage is in each grade of fuel.
Old Nov 15, 2022 | 08:39 AM
reacp911's Avatar
reacp911
I've just ordered a set of graduated cylinders from amazon. Should arrive today. I will report back
This was post my #666. Wonder if that is significant?
Old Nov 15, 2022 | 01:48 PM
911 Rod's Avatar
911 Rod
I guess this means I don't have to use premium in my lawn tools anymore.
Old Nov 15, 2022 | 02:27 PM
reacp911's Avatar
reacp911
This is likely why shell has not publicized this. It's going to cost them
Old Nov 15, 2022 | 07:46 PM
Greg981's Avatar
Greg981
I've always gone out of my way to use V-power. No reason to now.
Old Nov 15, 2022 | 09:42 PM
Adamant1971's Avatar
Adamant1971
A new shell is going up at Appleby and Dundas right close to my house. My excitement has been squashed.
Old Nov 15, 2022 | 10:25 PM
Matt Lane's Avatar
Matt Lane
Ethanol percentage can I guess vary by grade. Will be interesting to see what is done in practice.
Not going to help the cars, but what options will there be for carbureted home tools?
Cheers
Matt
Old Nov 15, 2022 | 10:54 PM
petee_c's Avatar
petee_c
Cheers
Matt
My Stihl stuff takes premium, i think because it's ethanol free... I'm not too worried... I think the vast majority of 'Merica has been ethanol blend for a while...
Will see if the Stihl dealer has any info....
I store my home made premix batches in aluminum fuel containers (Think MSR stove tanks) Apparenty ethanol not good for aluminum.... That might be a concern
If you're worried about it for lawn equipment, you could decant it after doing the graduated cylinder/water experiment.
Old Nov 16, 2022 | 12:15 PM
993GT's Avatar
993GT
it's honestly a non-issue for our cars unless sitting for many years unused, if you're worried about extended storage/lack of use then use an ethanol stabilizer
Old Nov 16, 2022 | 03:05 PM
steam_mill's Avatar
steam_mill
I use premixed, in my 2 stroke stihl and weed eater lawn equipment. Often times, multiple year old pre-mix. Never a problem and I'm just using Regular.
Stuff always starts and lasts for many years. I had to retire my weed wacker after 16 years and much use. Not the carb, it was worn. V. Low on compression.
