PCCM Plus
PCCM Plus
Finally, 2022 and waiting patiently for the rumoured release of the PCCM Plus for the 997.1
Porsche OEM
Modern entertainment and communications in an analog, driver's car
The best of both worlds if Porsche does this right
Porsche OEM
Nate Tempest (01-08-2022)
Heck, I wouldn't mind an OEM solution for my 981. CarPlay is super handy although its not a big deal to use my phone when mounted when needed. Most times its in my pocket or the glovebox.
Has anyone used this ? Joyauto ? Wouldnt mind upgrading to apple car play
Lots of info. I will be doing this, this summer. Approximately $1100 installed. I have Bose, so CDR31 head unit. Different module for PCM.
https://rennlist.com/forums/991/1045...991-1-a-2.html
https://www.youtube.com/results?sear...=cdr31+carplay
Love to get your impressions. I have an 2011 Cayman S - w/ nav and Bose so it would work with mine and would like to keep this stock not that it should matter given that I have modded a few key areas on my car. Other than the car play issue on my stock unit I am ok with it and perhaps a back up camera would have been appropriate which this manages to address both. LMK how it goes... Tks !
Greg981 (01-09-2022)
And while it’s under factory warranty you can’t install an aftermarket radio. It’s very frustrating.
Do you plan on doing the install on your own? if not, what shop do you have in mind?
Why can't PCM 4 just be a plug and play retrofit? That would be too easy right?
Hey Greg, I have seen this before but I have been hesitant to go down this route. An aftermarket unit would accomplish the same thing but allow me to easily go back to stock when I sell. Loosing parking sensors would be a pain though.
For me to go aftermarket would be more of a pain and more $ as I have Bose, which adds a separate amp under the passenger seat. I'll probably do the install myself though I may chicken out.
The following 2 users liked this post by Greg981:
maximusbibicus (01-11-2022),
myw (03-26-2022)
does this have a backup camera option with this upgrade as well ? Tks
Abe Evrens (01-10-2022)
