12 point triple square?
Hello,
I am trying to remove a bumper horn off the front bumper. I think the bolt head is a 12 point triple square but i am now sure. Would anyone in the downtown area or highpark area have a socket I can borrow? Or if you know where I can buy one. Check crappy tire and brofasco already.
Team Owner
that's not a triple square . Looks like a Polydrive to me . same as the Audi / VW head bolts and cam adjuster bolt.
in fact I have one right here at my desk.
Team Owner
its not a torx Will. Although you can modify a torx in some cases to get it to work. I am surprised that it is on a Porsche , they are widely used in VW / Audi. didn't know they had migrated to Porsche.
its this .. but not sure about the size.
sometimes they are called RIBE sockets.
https://www.amazon.com/ATLIN-Vehicles-Polydrive-6-Point-10-millimeters/dp/B06VWLVYTW/ref=sr_1_4/147-0936823-9910739?ie=UTF8&qid=1525892707&sr=8-4&keywords=polydrive+socket+set&dpID=31PbwCUtfXL&preST=_SY300_QL70_&dpSrc=srch
oh man thanks guys. so its even more difficult to find lol. I read on another forum that the torx will strip the head.
Its an OEM bolt off a 1972 911.....
1 Post
Torx is used all throughout the 996/997, I thought it was crazy when I did my first 996 engine. Both male and female torx are used.
Just finishing up a IMS Solution today, the flywheel bolts were T-55, right in Porsche baggies.
You can get a torx set at princess auto.
In this case it's torx but "triple square sockets" are just regular old 12 point sockets.
Team Owner
Team Owner
This may help OP
d
Torx was invented by the Americans in about 67 . I ram not sure you would find it on a German 1972 car. Don't you think the flats look more like a poly ? could it have been replaced at some point ?
and I'm not sure what you mean by a triple square is a 12 point socket. its dimension is similar but a triple square or XZN driver is required to remove it as it is typical a female bolt head.
CaptainSlowly (03-23-2024)
1 Post
As far it being a '72 I didn't know that till it was posted at the exact same time as my post. I thought it would be 996. So chill out.
I agree it's not OE.
I was wrong on a m10 TS fitting a 10 mm 12pt socket, looks like an M12 TS fits into a 10mm 12pt socket.
I was just asked recently for a triple square female socket by a guy using ARP rod nuts, they are just 12 points.
Thanks everyone for the help. I was able to get the bolt out. Im pretty sure it was a polydrive but I was able to use a torx socket to carefully loosen it.
Cheers,
Chris
Cheers,
Chris
