Targa New Zealand 2014
#46
Yes, more practice required. It's like all good things, you can never practice enough. I just read a note from Sean, looks like more practice Saturday getting ready for Sunday !
#48
Edit: double post not sure how to delete!
#50
#51
#52
^^^^ Totally agree. Its a torque monster and that's what you need for fast road driving. The 996TT is perfect for the job. I think it will be a far better Targa car than a track car....
#53
I've conditionally registered for the NI Targa on the basis that this weekend hooks me :-P
#54
#55
Believe it or not even on the NI Targa NZ we travelled through areas where GPS dropped out (Valley into and out of Whangamonima, under bridges, through tunnels etc). Same thing happened to me regularly in the ravines between the mountains in the Alpes of France back in Dec in the GT3, sometimes for a minute or longer at a time plus the acquisition and plotting time. Worse still you will need to mount the phone on the window and there's no way anyone is operating it as they are being thrown around the car. Lastly, battery life will require a charger, more mess in the car.
I spoke with length with the guy who owns and developed the Monit in 2012. We discussed his then new/proto GPS unit. There was an opportunity for me to buy one before release. However he warned me the unit would not work well in parts of the SI and central NI and that such units would not be sanctioned on any European vintage units due to GPS fall out. I want to take the 993 to Europe in 018 for some vintage Rally so that was the decider for me.
Get teh T100 or equivalent hard wire model if you can. Mount it somewhere close enough to the navigator that he doesnt need to lean from his seat to use it (not hard in a 993). I made mine removable on a flexi stalk with clip plugs at the dash that stash away under the factory carpet when not in use. Make sure you put a wheel speed sensor in and calibrate it properly. Properly calibrated its faster and more accurate than any non military spec GPS. You have backight, full time dedicated power supply and easy to use and feel buttons. Its designed and built as a rally computer not a phone - it does its purpose as it should. You wont find a historic rally or serious Targa car today with anything less than a hardwire unit with wheel speed sensor (or direct feed of the odo line form the cars factory wheel sensor as you do in an older 911). Dean knows how to fit and install cleanly.
Just saying, thats all. Its like Trackit. They made an iphone app but its not reliable and cant store and upload logs, worse still it requires constant power lead and you cannot use any phone functions while the app is running (its very resource and memory hungry).
If you like the Ecotour and want to try the real thing in Rotorua and SI towards the end of the year I afraid youll have to invest. Put into perspective both Monit + Trackit + installation is less than the fee for entering one 2 day event....
#57
That installation looks very nice.
I agree, if all goes well this weekend then I will be buying Trackit and Monit devices. The new Monit looks to be able to run in GPS or hard wired mode, so addresses the drop out issues and allows for some events which don't allow GPS devices.
The issue is just this weekend, I very much doubt we will be going out of cell and GPS coverage and it would be nice to have something to help practice the notes and instructions side of the event.
#58
Rally mobile apps
I'm about to test RaceChrono and GPS Tripmeter android apps. Some good comments from some who have used them in rallies. Just hope they play together nicely sharing the GPS signal or I may need to put them on 2 separate devices.
#59
Thanks, I just downloaded the GPS Tripmeter, looks nice and simple and seems to work okay. Just need to figure out a temporary mount for the phone now so Pete can use it on Sunday.
#60
For this rally spirnt I dont think you will need any form of rally computer myself. The course is short and you have recced half of it. However if you graduate to the full event you will need the hard-wire solution.
I think any one of a number of apps will be fine for the Ecolight event ...
