New PB @ Thunderbolt Code Brown @ End
Old 07-02-2017, 03:43 PM
Bill Lehman
Bill Lehman's Avatar
Default New PB @ Thunderbolt Code Brown @ End
I'm chasing a former PCA "I" Class Champion to a new PB followed by a Code Brown after a Cayman blows a radiator hose.
Old 07-02-2017, 04:11 PM
erko1905
erko1905's Avatar
Wow - that was close
Old 07-02-2017, 04:19 PM
Jferrante
Jferrante's Avatar
woahhh nice laps!
mikew968
mikew968's Avatar
Holy crap how did you miss hitting him!!!!!
Old 07-02-2017, 04:23 PM
987part
Former Vendor
987part's Avatar
It looks like you touched his door? It is possible?
If I can say something, i dont like your hands position.
Its too much 11-1 from my point of view. You keep on moving your hands. Stay 9-3 and hold them there!
You cant have "fast hands" like that with a position like that.
My 2 cents.
Old 07-02-2017, 04:27 PM
HelpMeHelpU
HelpMeHelpU's Avatar
It was like magnets with opposing energies that kept you apart. Nice driving and crash avoidance.
Old 07-02-2017, 04:53 PM
StoogeMoe
StoogeMoe's Avatar
Yikes that was close. I would have got the hell outta there instead of sitting in the grass waiting for someone else to come slide into you.
Old 07-02-2017, 04:58 PM
Frank 993 C4S
Frank 993 C4S's Avatar
Wow - glad that this didn't end badly.
Old 07-02-2017, 05:05 PM
mark kibort
mark kibort's Avatar
wow.. close call. even panic stops need to be done straight!
Nice to see you using 2nd gear as suggested around turn 5! nice laps!
Mark
Old 07-02-2017, 05:11 PM
mark kibort
you must be a synchronized swimmer.
Old 07-02-2017, 05:22 PM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,435 Likes on 768 Posts
Holy smokes. And then the white Boxster spins. Geez.
Bill you're losing a bunch of time hesitating in the last corner. stay in the throttle. The car will stick. Makes a real difference. Also IMO you're over slowing into 5 just to get down two gears...only to upshift again at track out. In a Cup with all the power up at 8000+ rpm that's a decent bet. In your car with the power band it has it's not. Go down to 3rd and don't slow quite as much. Makes a real difference in the GT4 in that segment. Also IMO over braking for 6.
Old 07-02-2017, 06:15 PM
mark kibort
Dave, that's non-racer talk... if you are over slowing, dont over slow, its that simple. has NOTHING to do with a proper gear change to get the car out of that turn with 2nd gear and maximize hp on the exit. (plus the control benefits we all talked about). yes, thats what you do.. you up shift on track out.... its what we do when we maximize forces to the rears. and dont worry about instability. the car has PLENTY of grip to use 2nd on the exit with the wheels pointed straight. over braking is an entirely different discussion and could be a possibility for both turns, but not due to proper downshifts.
you make an error in your assessment of his HP characteristics too. just because a cup car has its peak power at 8k rpm, doesnt mean you dont downshift a cayman. the cayman and other 911s have a power curve that is maximized from 6 to 8K. you keep the RPM here for max acceleration. anything in the 5k or even 4kRPM range (where you would be in 3rd) is a HUGE loss of power (near 50hp) and thus acceleration
currently, Bill is at 5000rpm at 51mph. If he didnt overslow, he could be at least 10 to 15% faster and the RPMs would stilll be just under 6k when he goes WOT on the exit with wheels straight. this is 3+ seconds of 50 to 100 hp more! i would also suggest not to short shift out of 2nd , 3 turns later.
I was thinking about you during the race this weekend when my transmission started to get hot, i went through 2 turns in a battle just like your turn 5 at NJMP . i did no other changes but that taller gear , which was very similar in proportions of RPM. lost near 1 second that lap.
Old 07-02-2017, 06:32 PM
Veloce Raptor
If you say so.
Bill, you be the judge. Cheers !
Old 07-02-2017, 07:00 PM
Frank 993 C4S
Good observations!
Old 07-02-2017, 07:07 PM
Bill Lehman
My 2 cents.
There seemed to be minor damage to his RF door, none to my bodywork. It looked like my LF wheel may have hit him.
Quick Reply: New PB @ Thunderbolt Code Brown @ End
