Brake Pads for HPDE
Originally Posted by erko1905
And to your experience, you can get through a 2-3 day event with one set of stock pads?
I guess will have to learn how to conserve. Or maybe pack an extra set.
Keep in mind that for the track it is best to replace them at 50% to minimize heat transfer.
As a green student I could use a set of pads for 3-4 event weekends. By the time i graduated to advanced I would use 65-70% of the stock pads in a single event. This greatly depends on the track, of course. The best part of using the softer stock pads was that I had the same stock rotors that entire time. As a matter of fact, they still have some life if I need to use them in a pinch.
Agree with this. If you use Hawk pads (like I do on my SM but not on Porsche), DTC pads are what you need for the track. DTC-30, -60, -70, etc.
I used the 70s on my E90M forever. They worked great at tirelessly hauling that 3800lb pig to a stop. Great prices from tirerack too.
Are those reasonably easy on the rotor?
A sad fact of life is that the drilled rotors crack.
According to the guys at 949 racing, one of the guys from Carbotech started G-Loc after some sort of split. Supposed to be identical compounds with (they claim) higher manufacturing consistency.
Used Hawk HPS & HP+. Poor at best . 6 DE on Pagid yellows, great wear, great performance. Flush fluid & use good high temp fluid. Don't chinch , it's your life and maybe someone else's
