Ford trucks
#31
I'll agree with the aftermarket intake and EGR delete. My 08 F350 does 20-22mpg all day long at 65-75mph empty. towing an open trailer w/ car and spare tires/wheels, jacks, tools, etc I am around 16/17mpg on flat ground, 14/15mpg in the TN/GA/NC/SC hills, both at about 75mph
#32
Pull the cab? Really? What are you talking about? Doing any intake, head, turbo, exhaust, etc work is VERY simple and straightforward. I Installed ARP head studs in a couple hours. And going from 14 to 22 MPG took all of about $1300 and maybe 8 hours of work. Not a bad investment return.
#33
#34
An air intake is not going to hurt a dodge diesel. Tuners can be an issue, but worst I have seen with people being stupid and boosting too high is a blown head gasket. No one I know, or any Forum I have seen has talked about replacing an engine. If you check, the worst you will find is the transmission (outside of the new Aisin) is the weak link.
#35
If something goes bad due to your air intake, chips, etc and you have to do something major to the diesel engine you will be into a major repair from the get go is what I mean. There is a sticker on my intake that states any change to the engine or ecu voids the warranty. New diesel engine is in the 12 to 13 k range.
#36
There isn't enough clearance to pull the heads with the cab in place after the 7.3s. It may even be necessary for the 7.3, but I don't think so. With the EPA requirements, there is a lot more crap attached to the 2003+ Ford diesels.
One of the reasons 6.0 and 6.4s are so cheap is either fixing them or bulletproofing them is so expensive - it's better just to buy a 7.3 or a newer truck.
I had a test ride today in a 2012 F250 6.7 with a car on an open trailer very similar to mine. That rig accelerated better than my Expy unloaded. However, it also road like a truck. Not terrible, just a lot more trucky than the Expy which rides like a luxury car.
-Mike
-Mike
#37
I have an F250 diesel crew cab long bed. Yes, it rides like a truck, especially running light.
But it's a LOT better ride than the 2008 and 2003 dually I had before it.
