Broken steel belt in tire?
Started picking up a pretty bad shake at 85 mph + at the track. Coincidentally grease started melting and coming out the center of the axle on my 993. Thought it was a wheel bearing.
Mechanic said to put in high temp grease but that the wobble was a busted steel band in the Nitto.
Is there an easy way to confirm the theory and if so, how to find which wheel? Something that doesn't involve 90 mph on public roads?
The tire with the broken belt will have a different gap at the point where it is broken.
It will also tend to be out of balance.
ive never heard of this... you would think that the tire would be out of round too, if this was even possible.
more than likely, just out of balance, as you might have shed one of the balancing weights on the inner rim area....
however, jacking the car up is a good idea. i would actually run the car in gear with the rear of the car on jack stands if this is a rear wheel .... or even mount the front on the rear for this test. spin it up fast and see if you hear or see a vibration
![](https://rennlist.com/forums/attachments/993-forum/870002d1410824091-axel-re-grease-8_23_12__-020.jpg)
I've seen broken belts on trailer tires, It looks like a knot or twisted distortion in the tread, pretty obvious when you know what to look for.
If u have a 2nd set of rims/tires put them on and see if it wobbles at 85+ mph. If not it's the tire or the rim or both. I would try to rule out there is no flatspotting or tires that rotated around the rim which would affect the balance. Also visually check the rim for nething bent or out of round. Mike
Basic Site Sponsor
Basic Site Sponsor
Received 3,187 Likes
If a belt has broken, it'll be clear when the respective wheel and tire is up off the ground and can be rotated on the axle or on a balancer. The distortion will generally be at the intersection of the sidewall and the tread. When you turn the wheel and look closely (or better yet, run your hands over the tread or rotate the tire with your hand stationary just above the tread), it'll be a pronounced lump or big, smooth blister.
It's more common than you might think.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
The grease seems to have melted. Street spec. Replacing it with track spec stuff. Vibration was prob 3 laps as I tried to diagnose what was going on.
glad it was a tire. wheel bearing grease is always a challenge . i tried the redline synthetic stuff once and at the track, became liquefied and ran out the seal cover. back to the litium based heavy duty high temp grease you get at local auto stores. seems to work ok
This type of stagger does not work
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Greg
