Solo DL - what data will an 09 Cayman put out of OBDII??
Old 11-14-2015, 01:25 PM
Gary R.
Gary R.'s Avatar
Default Solo DL - what data will an 09 Cayman put out of OBDII??
I'm curious what the Solo DL will pull out of the OBDII channels of my 2009 Cayman S PDK. Is steering angle in there? Brake PSI? Is there a list somewhere of what channels can be monitored? Seems like it would be a pretty sweet setup for my street car on the track without a big investment.
Did some digging, found this - http://www.m-world.us/aim_solo_dl_gp...ration_solo_dl
It does list 13 channels as available via OBD (22 wired directly to the ECU!), still not sure what they all are. It just says "While a Direct ECU connection offers more channels, PnP OBD2 already contains the most important channels for data analysis - speed, throttle, brake pressure, steering. Other channels are nice to have but not important. Note: Direct ECU is NOT PnP."
Old 11-14-2015, 02:05 PM
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
Received 1,009 Likes on 603 Posts
This is what AiM says http://www.aim-sportline.com/downloa...us_102_eng.pdf
I'm on my phone and didn't check the link you posted sonic might be the same.
Old 11-14-2015, 02:42 PM
Gary R.
Gary R.'s Avatar
Different link Matt, thank you. Unfortunately that link says it doesn't apply to my car:
• Porsche 911 (997 MK1) Turbo, GT2, GT2 RS 2007-2011
• Porsche 911 (997 MK2) GT3, GT3 RS 3.8, GT3 RS4.0 2010-2011
• Porsche Boxster (987 MK2) 2009-2012
• Porsche Cayman (987 MK2) 2009-2012
Please note: these connections will not apply to Porsche Boxster S, Cayman S and Cayman R
Old 11-14-2015, 02:50 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
Received 3,347 Likes on 1,900 Posts
I still think CAN (2-wire connection) is your best bet, Gary, but here is the sheet for the S and R Mk2 cars: http://www.aim-sportline.com/downloa...ns_105_eng.pdf
It's the deal to be able to use many of the in-vehicle sensors with this $699 device to get really good info, and more than that, to put it up on the video real-time with a SmartyCam.
The easiest place to find gains are the areas you can see that you've missed on, in your review... Resolves gearing questions, brake attack, amplitude and release, steering rate and amplitude and, most importantly, RIGHT foot rate and progression!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Old 11-14-2015, 03:00 PM
Gary R.
Gary R.'s Avatar
Thanks Peter, here we go, $699 turning into $1699 (w/SCam)!!! I saw (briefly) the pin out of the ECU plug, is it really just a matter of tapping into two wires? (I finally looked deeper into Matt's link and see a channel listing, still not sure what the 22 are in the Cayman S though.)
Old 11-14-2015, 03:11 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
Here's how you do it, Gary. I'll throw in the mounts, initial configuration and phone support for the install just for you!
Old 11-14-2015, 03:43 PM
Matt Romanowski
Rennlist Hoonigan
I missed the S part. I sent you a pm.
Old 11-14-2015, 04:11 PM
Gary R.
Gary R.'s Avatar
I'm 6 months away from seeing a race track again so I have lots of time to figure this out!
Old 11-14-2015, 04:21 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
No sweat, let me know if I can help!
Old 11-14-2015, 04:45 PM
Gary R.
Gary R.'s Avatar
Thank you Peter, see if you can dig up a list of available Cayman S channels!
Then I can get the seat, harnesses, and cage all set to run her in I Stock..
Old 11-14-2015, 05:07 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
Gary, the difference is in the ECU. Only listed channels that don't return info on a 2009 Cayman S are Brake SW2 (?, you get pressure and Brake SW1) and SM_Gear (have to use calculated or math in analysis).
Mk1 uses GT3/Bosch (channels listed BOSCH below) and Mk2 (your car) uses Siemens (listed SM below). The early cars showed only total steering angle, the later cars showed left and right.
There are more, but here is a comparison of relevant (but not all available) channels for each. Mk1 (2006-2008) on top, Mk 2 (2009-2012) on bottom. Both S models.
Old 11-14-2015, 05:54 PM
Beantown Kman
Beantown Kman's Avatar
Gary, you really ought to make the CAN connection for your SoloDL, as ProCoach advises. I can't recall exactly which channels you do/don't get connecting it via OBDII. But having done this myself, I was disappointed with what I was missing. The Siemens ECU in your car provides so much data via CAN. It's really worth the effort to access and use it.
Old 11-14-2015, 10:08 PM
marcus1249
marcus1249's Avatar
Gary, I second what bean town stated, I ran a dl via odb-ll for several events then switched to can and it opened up access to much move info,
Old 11-14-2015, 11:19 PM
Gary R.
Gary R.'s Avatar
CAN it will be, the connection protocol looks extremely easy and the data borders on F1 telemetry@! I'm very impressed, but I come from the dark ages where I was using a string potentiometer on my steering rod (78 SC) to see steering angle!
Thank you Peter, going to have to get my "Making sense of squiggly lines" book back out! Car needs an LSD bad IMHO (or I could just suck less), but data is so nice to see..
Old 11-15-2015, 10:38 AM
Bill Lehman
Bill Lehman's Avatar
I did the CAN connection per "Pro Coach's" photos on my 987.1 myself. I did practice my soldering before my attempt but everything worked well.
Quick Reply: Solo DL - what data will an 09 Cayman put out of OBDII??
