Design the Best Balaclava
#107
Why? The neck fabric bunching makes the sock cooler and baggier reduces fire damage the same way a loose fitting suit vs. a tight fitting suit and will prevent dragging when turning your head left and right correct??
#109
Basic Sponsor
However, once we strap in and get in the car, everything is wrapped tightly around us anyway. So, I wonder how much this makes a difference given what we do. But, this balaclava won't be that tight around the neck, just reduced fabric so it doesn't double up as much. You'll still have plenty of room for an air gap in places where we already have them.
Ha, yeah it's hard to hit the mark for everyone...no way to really accomplish that at our size. My goal is to make every version better in some way each time we produce. Ain't gonna be easy. But, absolutely nothing has been easy with this company, so I'm used to it.
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
#110
Stand has a new feature that incorporates an emergency helmet remover into the balaclava. Would love to see that feature, i believe they are licensing to others?
#111
Basic Sponsor
The idea is simple and effective. The only thing negative I could see in it was the thickness of it coupled with the balaclava. I do have two different ways of accomplishing safe helmet removal with less bulk, but I'm a bit far off from it. I need a couple more of me's. Just not enough resources to go down that path as of yet. It would be another area that I would seek patent protection in before releasing. Unfortunately, I've found out the hard way many companies aren't out to play fair. There are two large and well-known companies that have tried to steal my fabric ideas. Thankfully, my suppler is very loyal. So, I been a lot more calculating since then.
Coming to PRI?
