Design the Best Balaclava
Basic Sponsor
I've talked with many concerning balaclavas. If you could design your own, what would be different?
For example, one of the biggest complaints I get is the seams around the face.
Also for the seams on top of the head, many that I've seen do not use a true flatlock stitch and instead use a cover stitch. Flatlock merges two pieces of fabric together to get the flattest most comfortable seam while a cover stitch threads over two overlaying pieces of material, which looks the same but is thicker and less comfortable.
Also, I'm guilty of pulling mine down below my mouth so I can breath easier in my helmet. Anyone else do the same thing?
Any suggestions or comments are most appreciated!!
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
The seams on the opening close to the face could be uncomfortable depending on your helmet fit.
I have one that has the seams on the sides (rather than on top) which is very comfortable.
I would prefer them to be thicker over the ears and with a longer "skirt"so they are easier to tuck in.
Provide for a headphone cable and/or a drink line. A tighter fit under the chin/neck area would be nice as there would be less bunching up with the helmet strap.
I do not pull it below my mouth and thus prefer a tighter fitting one so it does not roll down.
BTW, I prefer single eye port.
Basic Sponsor
Regs state at least 6 inches on the skirt, but I think 8 is optimal for tucking in. I also started putting it on before zipping up the top half of my suit.
Could def do something that would gradually bring a tighter fit as it goes below the chin.
Thanks Juan!!!
Basic Sponsor
I also pull mine below my chin. I have no facial hair, so it's not as important.
I would prefer a larger eye port. I only do DE's and usually wear sunglasses with my helmet. A tight eye port makes wearing glasses difficult and can bend the temple of the glasses. Putting the glasses on top of the balaclava doesn't work well either - they move around. Another option would be two small eyeglass holes.
Basic Sponsor
Good point...a lot of guys wear glasses instead of, or in addition to their helmet shields. Thanks!
Basic Sponsor
Should be able to do that pretty easily (holes). Just trying to picture how easy or difficult it would be to put in the earbuds through the holes. They have to be small enough and stretchy enough to "reseal" that area.
WRONGLY ACCUSED!
Received 3,242 Likes
How about a balaclava which acts as a helmet eject system in case of injury. I have the bladder type of helmet eject but was told that not all of the emergency crews have the little pump to inflate the bladder.
I heard someone has a balaclava on the market which can be used to help pull the helmet off. Having never seen it I imagine it comes down past the neck and can be pulled out and away from the helmet to pry it off without injuring the person's neck.
I would buy something like that.
On another note, I prefer on big single eye port. Since I normally have some sort of facial hair a balaclava is a must for me. Plus it helps keep your helmet clean.
Basic Sponsor
The trick is to do it without affecting comfort. Will look into this more deeply definitely.
I think everyone should wear a balaclava for the reasons you've listed. Without one, there is always a gap between the helmet and suit that enables flame to reach bare skin.
One pet-peeve of mine is when the forehead area is too loose or large, causing the balaclava to pull down over the eyes everytime you put the helmet on. I sold a new Alpinestar at the track because of that issue. The 2 Sparco's I have are better in that regard.
Basic Sponsor
I like most of Juan's points. For the earphones, you only need one button hole located center, below the chin strap and just above the race suit collar. It only needs to be large enough to pass the 1/8 headphone jack, so standard shirt button hole should suffice.
Why do you think the Sparco hood is better around the forehead?...does the fabric stretch better or is it just a tighter fit?
Rennlist Hoonigan
which cost no drachmas
Stand21 makes the balaclava with the pulls to remove a helmet.
I would think the pass through holes would be covered with a flap so there is no hole.
Basic Sponsor
Yep, it is. Looks pretty good and it would cover any holes on the side. But, I would really want to hear from anyone that has actually tried this one out for comfort. There is a fine line with what drivers will wear when it comes to comfort, even if it's more safe. I like the concept of it, but it seems it would create another layer on the sides and necessitate a thicker layer where attaches. Most people that I've spoken with want thinner/breathable and better fit. Thoughts on this guys? Thanks Matt!
Other that what have already been covered with seams... something that will make it easier to wear glasses. I saw a guy at a race that had a balaclava that looked like it had little pockets / area for the ears. Looked like it would have been great for those that wear prescription glasses and have a tight fitting helmet like Stilio. I wish I had asked where he got it from... I would purchase a few of them if you could have a differentiator such as that.
