Motive Brake Bleeder - Replace old plastic fill tube!
Just a heads up.
I've owned my Motive brake bleeder for many years now and have successfully bleed my brakes with it for the past 7 years or so, until today!
While bleeding my brakes, after finally finishing up some winter projects, the clear plastic fill tube coming off the canister cracked and blew with 4 to 5 psi after closing a bleeder valve.
Needless to say that made quite a mess. If your lines look at all foggy and / or have some age to them, best they be replaced!
Must have been a 3 to 4 foot arc of Super Blue spewing out of my engine bay as seen from the rear drivers side...good times.
I'm surprised you made it seven years. Mine cracked the hose within 3 years as have 2 other people I know personally. It's a common weak point on an otherwise good design. The hose rotater thingy option may help, as I suspect some of it is due to stress when screwing on the M/C adapter without it.
-Mike
-Mike
Who puts fluid in the big container? I always top off the brake reservoir and then use the Bleeder for air pressure only. Down side is I have to removed/unscrew the hose from the reservoir every other caliper but everything stays much cleaner.
Kinda defeats the purpose of having one don'tcha think?
No. I'm just using it to supply air pressure for 1-man BLEEDING. Plus I don't have to clean out the tank each year to put in fresh brake fluid.
I'm not the only one who does this. I don't know of anyone that puts fluid in the Power Bleeder. It's just makes everything more messy.
How can you do a flush (not a simple bleed) without filling the container???????
I've always pumped fluid.
and tubing I switched to the no fluid in the container method.
AND, I only use about 5psi to bleed/flush . . . works just fine.
Regards,
I used to rinse it with water and leave it open to dry out, but it just wasn't worth it. It stays clean enough through regular use and storing it carefully.
-Mike
That's not really a down side considering there's less mess to deal with, and now it sounds like the hose needs replacement if you run it wet as well - one more benefit to running it dry. I think the manual says to bleed 250cc per caliper bleeder which can usually bleed 3 calipers before having to refill the reservoir on a 996. It only takes a minute or so to refill the reservoir and re-pressurize. And using a mityvac to drain the reservoir first is a great idea so fresh fluid runs through right away.
No. I'm just using it to supply air pressure for 1-man BLEEDING. Plus I don't have to clean out the tank each year to put in fresh brake fluid. I'm not the only one who does this. I don't know of anyone that puts fluid in the Power Bleeder. It's just makes everything more messy.
Yep that's what I do, I don't put fluid in the bleeder. Use a turkey baster (don't tell the wife! LOL) to suck out all the fluid in the reservoir, fill reservoir up, pump up to 10psi, bleed a corner, fill it up, bleed a corner, etc. Did a full bleed on the wife's MINI yesterday.
On my GT3 I normally just purge a few oz per corner after each DE event, and then top off the reservoir, will end up with a full bleed at least every 6mo or so.
We could probably have a class action of all of us whose hoses eventually burst, and then upgraded to the swivel cap and use the unit dry. Turkey basters last basically forever.
Interesting, I've always filled the Motive canister and used a turkey baster to remove fluid from the reservoir prior to bleeding. Up until yesterday I never really had issue with a major mess but may try to dry bleed in the future.
