Cool Shirt/FAST Connection Adapters
I need to connect FAST tubing to a Cool Shirt Cooler. I understand the connectors are not compatible? Could someone list what I need and where to source them.
Thanks,
JF
Thanks,
JF
Thanks Doug.
That thread is not clear for my application.
Has anyone connected FAST tubing to a Cool Shirt cooler? If so what adapters did you use?
Thanks,
JF
Thanks,
JF
I have the adapters...I believe I got them from the folks at FAST years ago?
OG racing has exactly what you need. It's an adapter tubing with FAST female ends (to accept your FAST shirt) and Cool Shirt male ends (to plug into your Cool Shirt cooler tubing).
$54 on the website
$54 on the website
If you follow the link to quick coupling site, and replace the cooler end with the quick coupling one, it will work for both brands of shirt. Both shirts will work with fast cooler, but fast shirt will not work with Coolshirt cooler unless you replace the fitting on the Coolshirt cooler (cheap), or buy the adapter (more money). There are other writeups about this on Rennlist. Do a search.
You can get all the cool shirt fittings from Mcmaster Carr. You can get them for either 1/4 or 3/8" tubing size. Easy pleasy.
