PCA 2015 slider ruling - ???
#76
If you put in a slider you can not use a seat back brace and still slide the seat back.
I would like to change to a containment style seat, but to do so and still be able to exit the car safely, I would need to have a slider.
Hopefully a good solution that is not prohibitively complex and expensive can be found
#77
The Penguin King
If you do not need or want sliders, the seat back brace is not a problem. If you put in a slider you can not use a seat back brace and still slide the seat back.
The components of the driver restraint system (belts, HANS, seat,...) are designed to have some give in them. It's all about spreading the deceleration out over a slightly longer period of time so that the driver experiences lower G-forces. Had I had a seat brace behind my seat, there would have been no "give" in the seat. My seat wouldn't have deformed, but I wonder about how my back would have fared.
#78
Rennlist Hoonigan
which cost no drachmas
#79
The second one was a crash a friend had in a 964. The seat mounts on one side partially failed, and he ended up breaking a couple of ribs. The theory was that he hit the door bar on the cage.
While I realize this may be an inconvenience, Walt is not doing this to be a pain. He's just trying to help keep us as safe as possible. I remember similar debates a few years ago when a HANS was required, or we started requiring cages (that was my suggested rule btw).
#80
The Penguin King
Just watch the Elliot Sadler impact at Pocono, and imagine what he would have experienced if his harnesses didn't stretch some.
#82
I do not know which incidents Walt used, but I have personally seen stock seat mounts fail twice. The first time was on a 914 that I owned. I crashed the car back in ~2002, and one of the rear seat mounts pulled out. I was lucky it was not a harder hit.
This opens doors for all kinds of failure. The stock (tub) seat mounts certainly were engineered by Porsche and homogolated into their race cars of whichever era they raced. (i.e. if the factory tub mounts were good enough for the 964RSR, they should be good enough for me)
To expand issues further, we are now talking about modifying seat (side) mounts and sliders to make them fit. Who on earth will engineer that, who will design the modifications and then pass them on through to the manufacturer to insure that the original integrity of the mounts and sliders are retained?
To be specific, what's wrong with MY current setup: 964 in good shape, Recaro double locking sliders, and proper side mounts/seat. Why on earth would I want to mess with this before I spend the same money to have my wheels Zygloed, or pay a reputable shop to nut and bolt the entire car to double check my work, or even flush my dang brakes yet again.
At what point do we draw the line...I'll wager that a far greater number of theoretical safety related failures in other parts of our cars (wheels, suspensions, brakes, oil lines, etc) will occur on track this year than seat mount issues.
#83
At what point then do we demand that seat mounts are reinforced? How and by whom and in accordance with which engineering?
I have had fix/repair numerous stock Porsche seat mounts
Broke my 964 seat mount at Watkins Glen two years ago.
I have repaired seat mounts in bunch of stock Porsches.
944's,911's,996's
I have repaired the tub on my old 79 911 too many times to count from fatigue.
Ripped out front sway bar mount
Front control arm mounting point
Rear spring plate mounts
Replaced rear sway bar mounts
Racing is hard on your Porsche and stuff fails over time.
#84
Safety? Really? I'm all in! Can we remove our passenger seats in our Stock Class cars? Now that would be a safety improvement.
I am having Boxster sliders installed now. It is a challenge in my old car. The sliders are taller and the pins require additional clearance. The seat sits higher and I don't "have a square to spare". I want welded in supports, not just through-bolt and backer plate mountings. Well, this raises them a little bit higher still.
One very nice thing about the Boxster sliders is their travel. With a halo seat and short legs, the extra travel make ingress and egress MUCH easier. That is a safety issues worth regulating.
#86
^^^ This what we are trying to fit in my SC. This system moves the seat way to high. Still messing with it though. Hoping to find a similar setup that allows head clearance.
#87
I talked to Recaro rep "Jeff". He stated that the seat slider shown here is only available as a complete seat/slider unit RECARO P1300. The retail price is around $10,000.00
#88
So I just got back from a test fit after my shop installed the Porsche sliders in my '87 911 in anticipation of the 2015 rule. And I'm happy to report that I am very pleased with the results.
My tech (a creative and capable fabricator) was actually able to LOWER the position of my seat with the new sliders while using the stock floor mounts (lowered and reinforced) and my existing (modified) BK side mounts.
None of the installation modifications that JWE has developed (rail extensions, custom side mounts) were necessary for my car/seat (Sparco Pro ADV).
And the Porsche sliders appear to be far superior to the Recaro/Sparco/Sabelt sliders I was using. The action is very smooth and mechanical with two pins engaging per side. I'm impressed.
I'll try to post some pictures when I get the car back next week.
#89
The first pic Doug posted above is my car. At the time, one of my forward, factory mounts was cracked, so combined with my need for a little more headroom, this is the configuration Scott came up with. Works fantastic, and definitely a lot beefier than stock, but as you can see, it's a bit of a mess to fabricate/install. We were already into stripping the interior and fabricating the cage, so no biggie at the time...
