Looking for wheel etc for use iRacing
#61
Charles - you need a 3 monitor telescoping mount for the wall so you can get those monitors about 3' closer to you and up higher (as I remember you are fairly tall?). I assume you use the paddles cause that shifter is a bit awkward, no? Turn the rig 90 degrees left and mount the adjustable monitor hangers on the sloped wall.. desk goes bye-bye either way.
#63
I know I've posted this here, somewhere, before... but this will be the NEXT generation: http://www.oculusvr.com/
I have a dev kit on order, should be here in a couple weeks, it's currently fully supported in iRacing. The dev kit version doesn't have a super clear screen... once their development is done, the "consumer" version will supposedly be HD.
If this is HALF as good as some of the guys in the iRacing forums are saying it is (even with the low resolution screen)... I will no longer be using my triple monitor setup.
Here's a vid showing the actual use of the dev kit in iRacing:
#64
Yes I got to find a way to bring the monitors closer... still it ain't bad at all. It looks worse on the picture, but I'm about 5 feet from them.
For the moment it had to be this to hide all the wires from my wife's sight...
c.
#65
Basic Site Sponsor
Basic Site Sponsor
From: Durham, NC and Virginia International Raceway
The Oculus VR is awesome! Got mine last summer!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#66
#67
Awesome. Been on the fence about ordering one for a while. Finally pulled the trigger last week - seems they're shipping much faster now. Can't wait!!!
From what I understand, the FOV is pretty good, you don't really notice the dark sides, and once you turn your head, you get accustomed. I guess the real key to resolving motion sickness is to make sure you have your IPD (inter-pupilary-distance?) calculated correctly.
#68
Basic Site Sponsor
Basic Site Sponsor
Takes a fair bit of time to set up (range of motion correlation between the image and actual position of your head) but except for the low rez rendering, it is better than any screen setup I've used...
#69
Basic Site Sponsor
Basic Site Sponsor
#70
I've used (or tried to actually) a TrackIR in the past and never could get it to work well. The issue was, for me, that I never hold my head still so it was always moving around and I would constantly have to hit the "re-center" button I programmed to get it looking straight ahead. Maybe a race seat with a halo would help..
#71
But I could never really fully get used to it - because while I could turn my head, I had to keep my eyes pointed straight (so I could see the monitor!) As time went on I started disabling some of the axes in it, down to the point where it only did up/down (because right/left became too disorienting). And eventually ~3-4 years ago, I quit using it altogether. It's collecting dust now.
The Oculus is completely different. Imagine using the TrackIR but having the monitors move with your head. It's also truly 3D, with separate images rendered for each eye. I hear that the immersion factor is unreal - you feel like you're really there. I know one guy in the iRacing forums commented that after spending an hour with it in a session, he took off his headphones and tried to hang them up on the rollbar... took him a second or two to realize that the rollbar wasn't actually there....
#72
I have a TrackIR and when I first got it (7+ years ago now) I thought it was the coolest thing ever.
So basically, what you say is that I can turn my head juste like I do in my car, right? That would be the best thing...
#73
Watch the vid I posted a couple posts ago.
#75
Just go triple monitor in the meantime. You can always sell the monitors once the consumer Oculus is available.
