Staubli quick disconnects for Motons
I just got my rear dampers back from moton with Staubli quick disconnects. I separated the reservoirs so that I could run the lines again. Darned if I can't get the disconnects to reconnect. Am I missing something here? Shouldn't they click together after sliding the sleeve back? Hopefully I don't have to depressurize the canisters... any advice is appreciated.
pull back sleeve slide together, keep pressure, release sleeve all should be happy.
What burns me is I can't find anyone who will tell me how to bleed the lines so you don't need the quick disconnects. Either it is a big secret or no one knows.
Rennlist Hoonigan
which cost no drachmas
Google Penske rebuild videos or look at the Penske site to get an idea how it's done.
I tried both ways, but it sounds like that wasn't my issue. I just talked AST and I need to degass the remote canister (Steve W. confirmed as well). I'll have to give that a shot after work. Of course now I need to find a nitrogen tank so I can pressurize again once things are reconnected
Yep, have to degass the canister otherwise it's imposible to get them to seat. Hit your local Roberts oxygen for a N2 canister/regulator then a Longacre N2 shock inflator, makes setting N2 settings a breeze.
http://www.longacreracing.com/catalo...d=1036&catid=5
Or order up one of these fine cases https://www.facebook.com/photo.php?f...type=1&theater
Having your own N2 rig is the best bet anyhow. if you assemble your own you can do it for around $200-250 all in.
Bite the Bullitt and get the N2 and inflation tool. One of the nice things about Moton is the ability to fine tune spring rates by adj N2 pressure. Sunce you now have N2 you can also use it for tires.
Peter
Peter
If you don't want to go the full route you could try discount tire or their local counterpart they usually offer nitrogen fills. You understand all this is a slippery slope. Get the new shocks installed, then add nitrogen to your tires. Why not add air jacks as well. Been here enjoy.
Rennlist Hoonigan
You can do that, but it's not the best way. The nitrogen is there to keep the shock oil from cavitating, not provide spring rate (which it doesn't provide much of). If you look, almost all other manufacturers are going to lower and lower N2 pressures and even going to things like through rod dampers to remove the spring effect.
If you have remote-canister shocks, you should have access to N2.
Easiest and cheapest for you would be to buy an "air pig" (portable air tank - 5 or 7 gallons), and get it filled at your local tire place if they offer N2 service.
Might not be necessary to always bleed to disconnect and re-connect, but it makes it easier as you're not fighting the pressure. It also reduces the risk of the quick-disconnect shutoff valve not closing right away, and causing you to lose some fluid. GL.
