best pump fuel?
Old 07-26-2013, 11:26 PM
  #31
Ritter v4.0
Ritter v4.0's Avatar
I don't know the chemistry/physics but I understood that higher octane run on a hot day will eliminate or at least reduce detonation.
Old 07-27-2013, 01:39 PM
  #32
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Absolutely true.
Old 07-27-2013, 01:41 PM
  #33
Ritter v4.0
Originally Posted by Steve Weiner-Rennsport Systems
Absolutely true.
Right for once- hurray!
Btw Steve- YGM.
Old 07-28-2013, 01:08 AM
  #34
dasams
dasams's Avatar
Originally Posted by Veloce Raptor
I said it helps keep the cylinder head at a lower temperature on very hot days.
Can you explain why this occurs?
Old 07-28-2013, 09:08 AM
  #35
Veloce Raptor
Veloce Raptor's Avatar
Received 1,539 Likes on 812 Posts
Because detonation AKA pre-ignition is often aided by extreme temperatures...and in turn detonation makes the head much hotter. Running higher octane (even if the engine is not set up to benefit from it) hinders/eliminates detonation, which takes a major source of head temps out of the picture.
Old 07-28-2013, 12:13 PM
  #36
por944s2
por944s2's Avatar
I run a blend of 93 and 100, especially for races and HOT days. Cool DE day's, 93 is fine. It would be great to find some 93 without Ethanol as well in NJ.
Quick Reply: best pump fuel?
