Mont Tremblant Video and Data
Looks like you are too slow entering namrow...I brake before the compression and let the hill scrub off the rest of the speed.
Does a 914 rotate like a 911 under braking?
I am now driving a 944 Turbo so many people may say I don't have an idea what I'm saying....
Rennlist Hoonigan
which cost no drachmas
I'll have to try that. The 914 is very neutral and rotates a little more like the 944.
you could be doing what that car/brake/brake pad/tire is capable of, I just noticed that the leading edge of the brake traces aren't as vertical as I'm used to seeing. but that could be the difference between cars/pads/tires on previous telemetry I've seen in the past.
I never really thought about building lat G quicker. I'll have to try that some.
You noticed the GT3 too? I felt bad....
I catch a lot of cars coming in and out of namrow now with the 944. I don't have to wait for the car to get in the groove before getting on the gas out of namrow with the 944.
I was sure you were gonna get by the 993 on the front stretch...
Did you try staying inside(right) coming into the esses? The 944 loves it....
Matt, I've never driven there... or seen data from there, so take my comments with a grain of salt.
The two big things I see from your data are: look at the deceleration rates on the speed trace (green arrows) and see how the right most one (last braking zone) has a much faster rate of deceleration (steeper slope). Why don't the other braking zones have that same rate of deceleration? If the car can slow down quicker, you can wait until *later* to start braking, e.g. staying on the throttle longer on the straights.
The second thing I see, is your brake release, trail braking. Look at the red arrows in the combined G chart. See how there's a dip between the braking bit and the cornering bit? There's room for improvement here! Again, since you're releasing early, you're probably getting on the brakes early...
Like Cups 'n Saucers, I do my best to never miss the event.
Rennlist Hoonigan
Good call on the slopes Van. It's funny how sometimes you (I) try to look really deep into the data and the basics are still right in front of you.
In general, I've been trying to trailbrake better. I still have a ways to go!
Can you post up a throttle position chart? There's usually room to improve throttle application...
Also, what are those little blips on the brake pressure chart in segment 2?? Looking at your video, you shouldn't have needed that...
It looks like - both from your video and your steering trace - that you're battling understeer once you get back onto the power. It might be worth making your rear shock compression a little stiffer and/or the front rebound a little lighter. This will slow down the transfer of weight to the rear when you get on the gas. You may also be able to play around with softening your front sway bar a little bit.
In a few corners, it looks like you apply the throttle some, then lift to get the car to rotate more, then you're back on the gas. If you plan your events a little better (and/or adjust the grip of the car a little bit), you can get on the gas a little *later* than you have been... but *omit* the lift, so you're actually at full throttle sooner.
That's just my 2 cents.
Rennlist Hoonigan
Here is a trace with the throttle position. The car is very neutral. I included a quick X-Y with steering and lat G too.
I recommend that you calibrate your steering angle to match the angle of the front wheels - not the angle of the steering wheel. That way, by comparing the front wheel angle to the akerman angle of the radius (based on corner radius and your car's wheelbase), you can graphically evaluate over- and understeer.
Be careful of the blanket term "neutral"... Race cars are very dynamic things, and with all the weight transfer and various inputs of the driver, nothing is static. Your car may be neutral at steady-state cornering, but that will change due to the weight transfer of trailbraking into the corner and accelerating out of the corner.
Have you taken John Block's AIM seminars? http://www.auto-ware.com/webinar_home.html I highly recommend them, and he'll get you to focus on looking at the data and correlating it to what you *feel* at different parts of the corner.
Rennlist Hoonigan
This car is very responsive and doesn't have any bad tendencies on entry, mid, or corner exit (even though it really should because of a couple suspension things). Having a couple of pros in the car have said the same as well.
