Minimun Brake Rotor Thickness
MO3O 968 front brakes. No wear groove (unless its gone?)
What is time to pitch it thickness?
Thank you...
Thank you...
Same here. My StopTech rotors have a minimum of 30mm, which usually occurs concurrent with the hairline cracks reaching the outer edge, which is the Danger Will Robinson sign to dump them anyway.
The minimum thickness is stamped on the edge of the rotors (usually). But, like everyone else has said, usually rotors on a track car are thrown out because the hair-line cracks start getting larger.
Same here. In the past I used to monitor against minimum thickness, but gave it up in favor of monitoring the cracks. When they start joining up or get deep enough to catch a fingernail I pitch 'em. This always happens before they even get close to minimum thickness.
