FS: 1988 944 ITS 944Cup GTS1
For Sale: ITS Class Champion 1988 Porsche 944 Race Car
Waterford Hills SCCA ITS Champion, 2012 and 2010
Car weights ~2360 dry and has 165hp at the rear wheels!
Eligible in SCCA ITS, NASA GTS1, 944 Cup or PCA SP2
Well sorted, developed and FAST 1988 Porsche 944 with the best of everything. Professionally built and maintained by Steinel’s Autowerks with no expense spared. The cost to develop this car was well more than triple the asking price along with several hundred man hours of work. Over $20,000 spent in 2011 alone to make the engine and suspension perfect. All receipts since 2006 will be provided as well as set up sheets, run history and results. Every nickel, turn of a bolt and lap is documented!
Recent service, corner balance & alignment by Steinels Autowerks and completed 2013 NASA annual inspection. Ready to race!
Over that past three racing seasons (2010 thru 2012), the car has been run primarily in the Waterford Hills Series with an occasional NASA Great Lakes event region (placed 4th, without aero, in the 2011 NASA Nationals, GTS1). In very competitive racing over this time, it has amassed 24 wins in 65 starts, along with two Waterford Hills ITS Championships!
Car is currently optimized to SCCA ITS specifications and is competitive in NASA GTS1 or 944 Cup.
Sample Lap Times on Various Tracks:
• Waterford Hills: 1:16.5 (Note: only 4 sec off the STO class record, set in a 500+hp Corvette!!!)
• Mid-Ohio (pro course): 1:41.2 (Note: SCCA ITS Track Record is 1:40.1 in a factory backed RX7!)
• Putnam Park: 1:21.9
• Grattan: 1:29.4
Fully-equipped and ready to race, the car is maintained by Steinel’s Autowerks in Twinsburg, Ohio and includes all of the following:
Engine
• 2.7L Complete Steinel’s Rebuild in April 2011,164rwhp,158ft*lbs at the rear wheels
- Gellner Engineering head port/polish and valve job
- Webcam 274 cam
- Forged & polished turbo rods
- Coated bearings by Ernie Elliott
- Lindsey knife edged crankshaft
- Lindsey Racing baffled oil pan
- Freshly rebuilt injectors
- Oil pick up extension
- Adjustable cam gear
- ASR lightweight pulleys: timing belt, alternator, balance shafts
• Lindsey Racing lightweight alternator bracket
• Lindsey Racing lightweight, racing alternator
• Lindsey Racing plug wires
• Miledge performance chip
• Lindsey Racing sealed cold-air box
• Amsoil cone air filter, 10inches
• Stahl header, jet coated
• Custom, 2 ½” exhaust quick change with straight pipe (or 2 other options: Borla or Flowmatster)
• Integrated, OEM Turbo oil filer housing for external oil cooler
• Earl’s high capacity oil cooler, -10 lines
• Lindsey Racing oil breather vent
• Lindsey Racing solid engine mounts
• Spec lightweight flywheel
• Spec 1 clutch
Transmission
• 944 Turbo 5-sp transmission
• Guard racing 50/80 locking LSD
• OEM Turbo differential cooler
• 4.11 ring & pinion
• Schnell short shifter
• OEM short 5th gear
• Solid transmission mount
Suspension/Brakes (full rebuild in April 2011)
• Leda adjustable gas strut w/custom length and valving, rebuilt in 2011
• Fabcar front lower control arms
• Full Racer’s Edge bushing/ spherical bearing package throughout the car
• Smart Racing bump-steer kit
• Kelley-Moss front strut tower brace
• Front height adjustable spring perches
• Racer’s Edge adjustable camber plates
• Tarrett Racing adjustable sway bars, front and rear
• Carbotech brake pads front and rear
• Eibach 500lbs front springs
• Coil over rear springs, Eibach 700lbs (no torsion bar) w/ adjustable spring perches
• Fresh wheel bearings/seals
• Braided stainless steel brake lines (F&R)
• Wilwood brake bias control
• Ducted front brakes
• Extended length wheel studs to accommodate spacers front and rear
Rims / Tires
• 1 set of late offset, 15x7 Porsche OEM “phone dial” rims, black, w/ Hoosier R6 tires
• 1 set of late offset, 15x7 Porsche OEM “phone dial” rims w/ Yokahoma AO32 tires
• 1 set of late offset, 15x6 Porsche OEM “phone dial” rims w/ Hoosier Radial Wet rain tires
• 23mm spacers, Porsche OEM, customized for front hub
• Available at extra cost:
- 1 set of BBS Motorsports rims, serviceable 3-piece, 15x10, w/ Hoosier R6 275/35R15
- 1 set of early offset, 15x7 + 15x8 Porsche OEM “Fuchs”, red
- 1 set of early offset, 15x7 + 15x8 Porsche OEM “Fuchs”, black, w/ Hoosier R6 225/45R15
- 1 set of early offset, 15x7 Porsche OEM “Fuchs”, black, w/ Hoosier R6 225/45R15
- 1 set of early offset, 15x7 BBS rims, 1-piece, silver
- 2 sets of late offset, 15x7 Porsche OEM “phone dial” rims ($200 per set)
Interior
• Full, custom roll cage from Mark McMahan (www.rollcageguy.com) w/ ouble NASCAR door bars, each side, for safety
• Extra, AutoMeter precision coolant temp and oil temp gauges
• 5lb, integrated fire suppression system both in the cockpit and under the hood
• Remote cut-off, 6 pole battery master switch
• Fully-stripped interior including dashboard, heater, fan, airbags, etc. removed, doors gutted and cored, all carpet, seats, headliner, padding, glue, sound-deadening, insulation removed
• Recaro Pole Position SPG seat
• Sparco, flat bottom, removable steering wheel
• Side mirrors moved inside the cockpit for reduced drag
• Wide-angle center rear-view mirror
• Window net
• Safety solutions center cockpit net
• NACA window duct for cooling
• Takata 6-point racing harness (new)
Body / Other
• Odyssey, lightweight battery
• IFC / Fiberwerks custom fiberglass nose
• Aero catch hood latches
• GT Racing fiberglass sunroof
• Air conditioning compressor removed
• Headlights and related parts removed
• Manual steering
• Removable Lexan side windows for hauling and storage
• Front and rear tie down mounts
• Rolled fenders to allow early offset rims
Spares List
• Quick change exhaust, Borla resonator
• Quick change exhaust, FlowMaster muffler
• Complete set of relays, including two spare engine relays
• Exhaust gaskets, 2 sets
• Upper mounting bolts for Leda shocks
• Spare front camber bolts
• Spare rear camber bolts
• Brakes pins (8), clips (4) and locking pins (8)
• Spare exhause hangers
• CV jount bolts, new and used
• Magnacore racing spark plug wires (2 sets)
• MSD Coil
• New Oil filters (3)
• Radiator drain plug
• Inner front hub seals (2)
• Rotor cap, button & cover (1 season)
• Spare rotor caps (3)
• New rear brakes pads, EBC Red
• Spare rear pads, rear, hawk blue & HT10, used (6 sets)
• New front brake pads, Hawk HPS
• Spare brake pads, front, Hawk HT12
• Spare brake pads, front, CarboTech
• Spark Plugs Bosch WR7DC+, new (4)
• Spark Plugs bosch WR6DC+, new (4)
• Spark Plugs NGK, BPR6ES, new (9)
• Front hub dust caps, outer (3)
• Air filter, cone, K&N, new
• Air filter, cone, Amsoil, used
• Brake rotors, front used
• Brake rotors, rear used
• Spare thermostat
• Simpson window net
• Fuel line hoses
• Wheel studs (30)
• Oil pan drain plugn & washer
• Spare shift linkage
• Fuel injector gaskets
• Spare lug nuts (20)
• Spare front wheel bearings & locking nut
• Spare tie rod end
• Front caster bolt
• Throttle stop
• Clutch throw out bearing (2)
• Sway bar bracket, Tarrett engineering, new
• Radiator hoses, complete set (2)
• Spare belts, including alternator and timing
Pictures
http://www.flickr.com/photos/9343721...th/8593075468/
Everything you need to go racing and win is here!
Offered at $12,500
Christian Cook
Christiancook43(at)yahoo(dot)com
• Grattan: 1:29.4
Engine
- Webcam 274 cam
• Spec 1 clutch
Transmission
Rims / Tires
Interior
• Window net
Body / Other
• Manual steering
Spares List
• MSD Coil
• Spare thermostat
• Fuel line hoses
• Wheel studs (30)
• Spare tie rod end
• Front caster bolt
• Throttle stop
Pictures
Offered at $12,500
Christian Cook
I've known Christian for more than 10 years he has been fastidious in his approach to developing and preparing this car. Whom ever buys it will reap the benefits!
JF
JF
