Want to do the occasional trackday - be aware of anything?
Hi All
I'm planning to do the occasional track day, maybe 1-2 a year in Taupo, NZ. Ambient temps anything from 5-25 degC. Is there anything I need to be aware of before I do? i.e anything apart from having reasonably new oil, brake fluid etc. Do I need to be aware of any oil starvation issues, is there anything I really " should be doing" before tracking the car? tyres will be standard ones. I'm not a really good driver by any stretch....
I'm really wanting to know about technical/maintenance issues rather than how to drive etc.
Cheers
Matt
_________________
2005 C2S aero kit, Post IMS updates?, short shift, PSE, Chrono Plus, Bose, Sports adaptive seats, Full Black leather with ALum dials surround.
Cheers
Matt
_________________
The first thing you should buy is a helmet and the second a good tire pressure gauge. I'd suggest you bleed your brakes at the beginning of the season. Nothing else required (at first).
The most important thing you can do is select the right group to run with. As evidenced by another post in this forum some organizations put on better track days than others. If you select the right group you'll have a safe well-organized day with good instruction; if you select the wrong group, not so much.
Not sure what options you have down in NZ, maybe someone else can help with specific recommendations.
Make sure that you have an event with instructors. PCA events are known for good instructions and are run relatively safe and structured compared to other events I participated in. There is lots of stuff you could do but make sure that your car is inspected. There are checklists out there that you can use if you perform your own inspection.
Check out some track notes or lap videos ahead of time once you know the track you will be going to. When you get there, the instructor will show you the proper line and detailed instructions, but seeing the track ahead of time and being broadly familiar with the layout and flow will be one less thing to worry about on your first day.
Congrats, and just a warning that it's addictive!
