PCA 2013 Rules Should Be Released Today?...
#77
Don't get me started on the remote res. shocks!! Or the stock brakes either!!
#78
Rennlist Hoonigan
which cost no drachmas
In my opinion, the chip change is a minor issue, some of the fastest racers I know run in the e stock class and its their ability that makes them fast, the car is icing on the cake. I am new to club racing and thought I needed new tires and the best of everything to compete. The reality is I have run my fastest times in the heat of battle with tires on many heat cycles, not in qualifing on stickers. I have to face the fact that only becoming a better driver will get me to the top of the pack. and if I ever get there, then the costs will go up to be able to compete with the best . But who said racing porsches in any class was cheap.
#81
As for brakes, PCA"s opinion is that larger brakes would drive up costs over the stock setup. Well my brake budget is right behind tires for a season. I use 4 to 5 sets of pads and a set of rotors each year to the tune of 1800-2000 dollars. Let me put 930 brakes on the car and one set of pads will get me through the year. After 2 seasons I'm ahead of the game.
#82
1. The OEM chips are NLA
2. The OEM chips can EASILY be reproduced and branded "OEM"
3. An aftermarket chip can and will be used to increase performance over stock
4. Upgrading this chip goes clearly against the spirit of the "Stock" ruleset and they can't use the "Genie is already out of the bottle" excuse as they did for the remote reservoir shocks.
You can't let a certain model/year of car within a class upgrade their car mid-stream without allowing something for all others within that class, which would be a nightmare. This isn't a new class, the 3.2's, especially with the 100 Lb. weight reduction already allowed this year (for G50 cars, 33 lb for 915 based cars - thanks Jack), have not been dominated because of their car. Evan is right at the pointy end now, and I bet if Dwayne M. put some laps down with his car he would be right where he is, if not faster.. I planned on building up to E this winter but if the rules for the 3.2's are going to be modified (for performance) every year I may just not bother..
#83
#84
Actually Gary, it was only the G50 Carrera that got the 100+ lb weight reduction. The 915 Carrera (Evan's car), only got a 33 lb reduction (from 2812 to 2779). Not completely inconsequential but certainly not a "game changer" either.
#86
#90
