AIM Solo, Replay XD1080, and TrackVision
Old 06-10-2012, 07:20 PM
Carrera51
Carrera51's Avatar
Scott:
Tony will be able to get you set up. Like Peter, he knows a ton about this stuff especially Track Vision. On another note, your car looks awesome!
Old 06-10-2012, 07:26 PM
winders
winders's Avatar
Originally Posted by Carrera51
Scott:
Mark,
I got it all working just fine. As I said earlier, figuring it out was not that easy. But, now that I have done it, it should be straightforward from now on.
Thank you for the compliment on the car. It drives better than it looks!! I am having a blast driving it!
Scott
Old 06-11-2012, 12:15 PM
HiWind
HiWind's Avatar
Originally Posted by HiWind
Anyone using dashware? I've got the new 1.3 version and works fine except for RPM. I sent my file to them (Rolf) and he said it worked fine on his side ie RPM did. Any ideas what setting I could have wrong? help!
Rolf from dashware came back about the minut I posted here - lucky.
Seems the gpx file is not the way - CSV or xcel with all output is necessary and that did the trick.
Old 06-11-2012, 03:46 PM
wanna911
wanna911's Avatar
Originally Posted by teamking
I've been using RaceRender with my AIM SOLO and Replay XD1080. Don't know how it compares to TrackVision, but it's pretty easy to sync the two inputs. Rendering takes a while, but my laptop is old and slow. Here's video/data from Tuesday at Summit Point:
http://youtu.be/ol7vZimnWrg?hd=1
+1 on Race Render, I use that too.
Old 06-11-2012, 06:54 PM
Tom W
Tom W's Avatar
In the for what it's worth department, in addition to trying to use the GPS from data and start/finish to sync data and video, you can also do a big throttle blip at the beginning of the video (so you hear it in the video and can sync it to the data).
Old 06-11-2012, 07:16 PM
winders
winders's Avatar
I have a brake light on my dash that the video camera records. So I can easily match up a braking event in data with the light on the dash. This works great because I can see when I brake in my videos and use it as a sync tool.
Scott
Old 06-12-2012, 01:52 AM
HiWind
HiWind's Avatar
Yes I'm trying a triple blip as leaving the pits to make synch ... solo dl seems to start 'recording' just as car begins to move
so that shd work too but not as easy. Here's my first data id - please let me know if I'm missing some easy/clever displays/data
that can help identify where I'm slow (obviously the corners - I got annihilated in the first turn 1 after surfboard on the inside locked up
... which made for some fun catching up)
Finished 2nd overall thanks to a better first heat.
thanks, Matt
ps - does vid look stretcheeeed wideways?
http://youtu.be/Aoo6v_wMhw8
Old 06-12-2012, 01:59 PM
acao
acao's Avatar
The Solo DL stops receiving RPM data from my car when the key is pulled. I use that moment, indicated with a hand signal, to sync. Hand signal showing key removal = 0 RPM.
I also confirm the sync with gear change data from the warm-up lap. The Solo DL gets the gear change data, and the video shows the shift being performed.
Old 06-14-2012, 01:54 PM
APKhaos
APKhaos's Avatar
The original video frame looks OK but the dash rendering is obviously stretched - aspect ratio error in the rendering. Getting those ratios right for all input video formats and all scaling factors is the secret sauce, of course
Old 06-14-2012, 04:42 PM
HiWind
HiWind's Avatar
Working on it - prob is rendering takes a while - change my GoPro recording setting?
Old 06-15-2012, 08:48 PM
APKhaos
APKhaos's Avatar
720p @ 60fps is about the best for in-car work.
Rendering time for a given frame size & fps combo depends on how smart the rendering app is. TrackVision uses video game tricks to run most of the rendering in the GPU rather than the CPU. Much faster that way.
Old 06-16-2012, 01:47 AM
HiWind
HiWind's Avatar
Thanks TK I'll try that ie 720@60 - my laptop not ideal but desktop 'in the shop' w big NVidia
Old 06-16-2012, 01:59 AM
HiWind
HiWind's Avatar
Thanks I'll check that out too ie parc ferme shutoff. Re gears are you calc'ing or actually getting that via odbII?
Old 06-19-2012, 03:28 PM
APKhaos
APKhaos's Avatar
AiM Solo guys - heads up!
We've recently seen a cluster of Solo users having problems with syncing data & video. Many of these were early Solo users who had been using TrackVision with their Solo data for a while.
We identified the problem as a data gap between end of lap and start of the new lap. It was very easy to document once identified.
AiM USA took it on [thanks Josh H], and AiM's Italian development group today confirmed the version of Race Studio that corrects the problem. Solo users should download & install - Race Studio V 2.46.02
Old 06-19-2012, 03:48 PM
acao
acao's Avatar
Actual gear data via CAN. I couldn't get the info via OBDII (calculated or actual).
Quick Reply: AIM Solo, Replay XD1080, and TrackVision
